Bunk Hinge Placement on 1977 Boler - Fiberglass RV
Old 08-02-2010, 11:09 AM   #1
Hi,
I'm a new owner of 1977 Boler. All the cushions have been recovered, including the upper bunk. As I washed all the coverings & aired out the cushions, I had to remove screws from the hinge, although I left the hinge in place. However, I am not sure that this L-shaped hinge was reinstalled properly by a PO, so am wondering if anyone can tell me how the hinge should be.
Right now, it appears as the the top of the L hinge itself would act as a support resting under the the bunk, which, even for a child seems a little worrisome (See A in attached drawing). Should the bunk instead hang down from the hinge (? thanks for your help.
Amy W is offline   Reply With Quote
Old 08-02-2010, 11:42 AM   #2
Joe N's Avatar
Trailer: none
Wyoming
This is a picture from someones post about the hinge attachment in a scamp.
http://cdn.fiberglassrv.com/forums/a...1&d=1280149972
Joe N is offline   Reply With Quote
Old 08-02-2010, 09:07 PM   #3
Kevin H.'s Avatar
Trailer: Boler 1300 1969 (flat roof)
Hi Amy, in my Boler, it is similar to your original installation drawing except that the hinge is about 2" inset from the edge of the top bunk plywood base. Mine is definitely the original arrangement, the top bunk wouldn't be able to fold down properly if it was attached like your 'B' diagram.
I thought it seemed flimsy as well, but in use it's very sturdy, I think the max. weight is about 120lbs. My 4 year old has slept there and also jumped around up there quite a bit with no worries.
Kevin
Kevin H. is offline   Reply With Quote
Old 08-03-2010, 09:29 PM   #4
thanks for your help!
Amy
boler
Outside outlet Placement joelh Modifications, Alterations and Updates 6 07-13-2010 03:40 AM
Employee Placement Benita Jokes, Stories & Tall Tales 0 08-14-2007 07:10 PM
Bunk hinge shelf/ledge thingy Valerie G Problem Solving | Owners Helping Owners 8 07-12-2007 08:54 PM
Microwave Placement LeBoutillier Modifications, Alterations and Updates 13 04-05-2006 01:45 PM
Coleman Black Cat Placement Legacy Posts Problem Solving | Owners Helping Owners 5 10-30-2002 09:21 PM
