Bunk Railing - Fiberglass RV
Old 04-24-2006, 11:15 AM   #1
Trailer: 1984 13 ft Scamp
Hi, folks! Finally getting around to planning that first trip in the Scamp. Lots of little fix-ups were needed, and now we've got a couple of kids to bring with us!
I know I've seen info on this site for building a railing system of sorts for the top and lower bunks. Any ideas? I'm not particularly handy, but think I could saw some PVC pipe (or similar material) and glue it together.
Any ideas would be welcome! Thanks - can't wait to get out on our maiden voyage.
-Amy
Amy M. is offline   Reply With Quote
Old 04-26-2006, 08:45 PM   #2
Gigi's Avatar
Trailer: Love Bug 1974
-Amy
Amy, here is a thread that may help.
bedrail link
Good luck!
Gigi is offline   Reply With Quote
Old 04-26-2006, 08:51 PM   #3
Then too, there's this one:
Escape Trailer Bunk Bed Rail, Concept should work on other models
It's made out of copper pipe, but you could make it out of PVC as well.
Old 04-27-2006, 10:28 AM   #4
I couldn't find a good picture of a Scamp bunk bed, but I believe (hope) it is similar in concept to the Casita front bunk; I assume the upper bunk is held in the position with two metal poles. If my assumptions are correct, then perhaps the following will be of help.
This picture shows my idea, sorry it is pretty crude. The red lines represent white PVC pipe, I used red lines for clarity. The concept is to assemble a bed rail with rails for both the upper and lower bunks. The metal bunk support poles will be inserted into the hollow vertical legs of the bunk bed rail assembly and the beds will be left in the up position. If you can't travel with the bunk beds in the up position then selected joints of the bed rail assembly can be left unglued so that it can disassembled for storage. I assume the beds will be left up so I didn't account for disassembly in my notes below.
I would take the bunk bed support pole to the hardware store and see which size of white PVC pipe fits best around the outside of the bunk bed support rail, I hope a 1 inch PVC pipe works. There are two different types of PVC pipe, Schedule 20 and Schedule 40, they both have the same outer diameters but have different inner diameters as the Schedule 40 is thicker, I suggest you use the Schedule 40 if possible. The bunk bed support pole doesn't have to fit tightly into the PVC, a little slop may be better as it will make installation easier. The hardware store folks can help select the pipe and other items. You could use copper pipe, but PVC is easier to work with.
If the bunk bed support pole does fit into a PVC pipe, then I suggest buying the following:
8 Slip Fit T Fittings (No threaded sections)
4 Slip Fit Elbow Fittings (No threaded sections)
4 Slip Fit Female-Female Couplings (No threaded sections). These will come in handy for splicing pipe sections together to correct errors or optimize the use of available pipe material.
PVC Pipe Cutter
PVC Pipe Cement
I like two rails for each bed for both safety and structural reasons. I assume you will need to buy two 10 foot sections of PVC pipe. You can easily determine your requirements by measuring the distance between the posts and multiply by 4, then measure the distance from the bottom of the lower bunk to 8 inches above the upper bunk and multiply by 2. The total should be pretty close to what you need.
When assembling the rails, the only critical dimension is the distance between the posts, for everything else as long as the left side matches the right side you should be OK.
The long vertical legs of the rail will be hallow so can insert the bunk bed support poles through the rail before you put up the bunk bed. The bed rails should be high enough to keep kids from rolling over it but not so high that pressure on the top rail can provide enough torque to cause failure. I suggest the space between the bottom rail and the mattress, and the distance between the rails be no more that 2 ½ inches.
After you cut all of the PVC pipe (easy to do), I suggest you assemble to pieces together and install it in the trailer. You can then disassemble the upper rail and glue it back together piece by piece. DO NOT GLUE ON THE LOWER ELBOW FITTING. The elbow fitting will be glued on last to allow for final adjustments to the rail assembly. You don't need to use much glue, in fact you should use as little as possible. Be very careful to not spill any in the trailer. If the pipe section fit tightly together you may not need to use any glue, but I would just for the added security.
After the upper rail is assembled, remove all pieces and assemble the bottom part of the rail. DO NOT GLUE ON THE UPPER ELBOW FITTING, this is the same elbow fitting discussed above.
Reinstall the partially completed rail assembly and tweak the unglued elbow fittings as required to get the upper and lower rails to match. Glue the elbow fittings in place and you are good to go.
I think this will work, let me know if it works out. Post a picture if you can.
Thane is offline   Reply With Quote
Old 04-27-2006, 10:59 AM   #5
Sharon Herman's Avatar
Trailer: 1979 13 ft Trillium
-Amy
Not sure if you are looking for full containment or safety to prevent falling out. I needed the safety for falling out of the top bunk. I bought a twin bed rail from babies r us that slips under the mattress. It has two long arms that are what you slide under the mattress/foam. It fits between the foam and the wood. I had kind of crummy covers so I didn't mind experimenting on them. I just slit two holes in the fabric and pushed it in. Worked like a charm. I just recently had new covers made and the gal put two button hole like openings where the arms will slide in. She reinforced them and while I haven't taken the kids out yet with the new covers, no reason it won't be just as great. I haven't re-attached the top to the wall yet, so I can't take a picture to show you. I will be doing that this weekend and will post a photo then.
Sharon Herman is offline   Reply With Quote
Old 04-27-2006, 12:01 PM   #6
Thanks, everyone! Wonderful ideas! I am debating making the entire PVC structure as detailed, or trying the bed rail through the mattress idea. I am so excited about this!
Thanks for your great ideas!
-Amy
Old 05-01-2006, 11:42 AM   #7
-Amy
Thanks again for the suggestions. We gave it an overnight try in the driveway this weekend. I ended up using the idea that Sharon suggested - it worked perfectly. However, my little one decided at about 9:30 PM that he'd rather sleep in his own bed (back in the house!) Guess the practice run was a good idea. A little Jiffy-Pop popcorn, some Richard Scarry books, and that was enough for him (and therefore all of us!) I see many fun adventures ahead of us, guess our little ones need to get a little bigger. We'll try it again in a few weeks, perhaps?? No need to leave the driveway yet!
Thanks again, everyone! Can't wait to join the ranks of those who actually leave their homes with their campers!
-Amy
Old 05-01-2006, 05:55 PM   #8
Mike Watters's Avatar
Trailer: TrailManor (Gone to the Darkside)
Another idea for your consideration:
When I did a bunk rail for our Boler (1/2" copper pipe) I got some pipe insulation and covered the bare pipe with that. I thought it would be more comfortable than the bare pipe (and look better too). Attached it by wrapping it with electrical tape in a few places.
mkw
Mike Watters is offline   Reply With Quote
Old 03-29-2022, 07:43 AM   #9
16 years later... I found this thread and ended up building a modified version of the PVC pipe railing idea, using 1" PVC pipe.
I glued everything except the two top elbows where they attach to the two uprights, so the whole assembly can be broken down into three pieces for easy storage/transport.
Matt Hyland is offline   Reply With Quote
Railing for awning on 77' Scamp Danielle Ash Problem Solving | Owners Helping Owners 3 05-13-2010 12:01 PM
Bunk bed Graeme Problem Solving | Owners Helping Owners 3 05-08-2010 07:38 PM
Bunk Bed Rob M General Chat 4 01-13-2008 06:29 PM
Bunk Bed Slocamper Modifications, Alterations and Updates 8 07-25-2006 07:12 AM
Bunk Bed Legacy Posts Problem Solving | Owners Helping Owners 10 06-28-2003 10:56 PM
