Burnt fiberglass fix? - Fiberglass RV
Old 06-22-2013, 07:46 PM   #1
Trailer: 1976 Scamp 13'
We just took the kitchen out of our scamp. After we removed the old nasty fridge we noticed that the whole inside of the kitchen body is burned for some reason. It had been painted over and the paint was bubbling up. We at first thought it was because of poor pre-paint prep but now we think it was heat. Is there anyway to fix burnt fiberglass or do we have to start over?
Christin is offline   Reply With Quote
Old 06-22-2013, 08:06 PM   #2
carlkeigley's Avatar
NE Oklahoma
Pulled this from a boat forum:
The toughest part of the repair is going to be getting the repair laminates to bond to the surfaces that have seen the fire damage. The soot and oxidation is going to be a real bear to remove to the point where you get an effective bond. In my experience, epoxy bonds better to dirty polyester than polyester does, but neither of them bond well enough to make a solid repair if there is any fire residue left. You are faced with having to do an intense amount of sanding to get a good faying surface. Since it will probably be less than ideal, epoxy is the choice by default.
Fiberglass Fire Damage - How to Fix? [Archive] - The Hull Truth - Boating and Fishing Forum
Old 06-22-2013, 08:07 PM   #3
So, the problem is inside the refrigerator cabinet? Or the outside cabinetry? Have you tried to scrape off the paint to see if there's any discoloration? Maybe they just used some sort of paint that doesn't handle heat well....
Old 06-22-2013, 09:13 PM   #4
Thank you Carl, that is really helpfull! The damage appears to be on the right side of the Cabinet, exactly where the fridge is facing a wall also the front over the top of the fridge. I sanded a little bit down, couldn't find any discoloration (only the yellowing from the age) the problem is those "bubbles" in the fiberglass. I just don't know if its worth the effort, it's also cracked on one side...
How to Fix Fiberglass from the Front? morbank Problem Solving | Owners Helping Owners 24 06-24-2012 10:04 PM
When is fiberglass too far gone to fix? CeliaL Problem Solving | Owners Helping Owners 7 07-15-2011 06:43 PM
Cracked and Broken Fiberglass Fix it Yourself Highway68 Care and Feeding of Molded Fiberglass Trailers 16 03-20-2010 09:46 AM
How do you fix Fiberglass cracks SharonNDean Problem Solving | Owners Helping Owners 12 02-12-2008 08:46 PM
Dont fix it Legacy Posts Jokes, Stories & Tall Tales 2 11-27-2002 12:40 AM
