Burro Door on Boler Trailer - Fiberglass RV
Old 05-17-2017, 12:01 PM   #1
nickkystardust's Avatar
Trailer: 1973 BOLER
Does anyone know if the door off of a Burro would work for a 1973 Boler? Would any other parts transfer over seamlessly? Just curious if anyone has any experience with this. Thanks!
nickkystardust is offline   Reply With Quote
Old 05-17-2017, 12:21 PM   #2
Mike Magee's Avatar
Trailer: 2012 Escape 19
Different mfrs, very different body parts.
Old 05-17-2017, 12:24 PM   #3
Trailer: 1973 BOLER
Ok, yeah I figured there might be some pretty big differences but found a local seller who has some parts I thought I could swap. Thanks for the info.
Old 05-26-2017, 09:59 AM   #4
Trailer: 1970 Boler
I put a new door purchased from scamp on my 1970 boler. Finally just mounted it yesterday. It will work but the doors for the scamp are about 3/8" narrower in width than the boler door which leaves the gap about 3/16" wider on each side of the door, but it will be managable and the port hole window looks cool on the boler.
J-barn is offline   Reply With Quote
Old 05-27-2017, 06:24 PM   #5
Trailer: 1973 BOLER
Good to know, thanks for all the feedback.
Old 05-27-2017, 06:38 PM   #6
Trailer: 1970 Boler
Also worth noting is that the latch striker plates are different. The scamp uses an extended striker plate to catch the latch but I don't like it because it protrudes out into the doorway and clothing can be caught on it. The bowlers striker plate is low profile and in the same plane as the doorway opening. I'll be modifying the scamp door with a reinforced area so I can mount the latch further out and use the original boiler striker plate. I'll try and post some pictures.
boler, burro
Redoing Burro door hinges - door fell off! AndyW Problem Solving | Owners Helping Owners 10 12-30-2015 12:39 PM
burro door repair and door gasket fred wark Care and Feeding of Molded Fiberglass Trailers 3 11-29-2015 06:25 AM
Boler door hinge repair kit and fridge access door John Jesse Problem Solving | Owners Helping Owners 5 05-27-2011 12:32 PM
Door Risers.. Door Props.. Hatch Holder upers?? earl squirrel Problem Solving | Owners Helping Owners 2 05-23-2011 05:07 PM
