Burro floor wet under the linoleum: is this a condensation problem? - Page 4 - Fiberglass RV
Old 01-17-2012, 06:31 AM   #43
cpaharley2008's Avatar
What happened to rest of this thread?
Old 01-17-2012, 07:24 AM   #44
Raz
Raz's Avatar
Vermont
Originally Posted by rabbit View Post
As an addendum on the great Flange Controversy, it occurs to me that when the halves of Humpty were laid up, that flange was basically there to get em to "pop". All molds have draft or taper in the direction of eventual removal of the part (if they don't the part is very effectively trapped and the mold has to be destroyed to get it out). I have seen shallow draft molds from which parts jumped up or popped on their own and I have seen some that took a lot of compressed air and prying to lift. Can't pry without something to pry against so I'm guessing that the flange is primarily a place to put a wedge or crow and also some reinforcement to maintain the shape of the part at what becomes the centerline when mated with other half. More of a fabrication necessity than a contributor to final strength of the centerline joint.
jack
While I am not disagreeing with you on ease of extraction from the mold, Trilliums don't have a flange just a thickened band where the two halves meet. They also are notorious for belly band leak issues. Last Fall I got a chance to examine a new Scamp. I took particular note of how much better the belly band was constructed. The flange becomes the first line of defense against leaks with sealing the seam second. On Trilliums all you really have is the seam seal. Not as good in my opinion. Second , take a piece of sheet metal. Very easy to roll up. Now, bend one end 90* and try and roll it. Whether intentional or not, the flange has to add strength. Finally, good point on the taper of the mold. While obvious, it never occurred to me the limitations the mold puts on the appearance of the body. The shape of the Burro, in particular the lights, could not be easily done with a horizontal belly band. You couldn't get out it of the mold. Raz
Old 01-17-2012, 10:01 AM   #45
jen b's Avatar
Trailer: 1980 13 ft. burro
Jim, if you're wondering where the rest of the story has gone, I updated about the flange removal in the Winter Makeover thread here.
The short version is: I'm pretty doubtful the flange had any structural role and it's likely we made the whole thing stronger by joining the two hulls together on the outside that formerly had only been glued together on the inside.
jen b is offline   Reply With Quote
Old 01-17-2012, 07:09 PM   #46
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Raz, I agree that a right angle flange is the beginning of a load-bearing beam. Sort of an el beam if you will. I also agree on the tail light nacelles on the Sac City Burros. They look like a mold-maker's nightmare. The Escondido variant has recesses for the lights. The box shape protruding on the inside of the mold which creates the recess would appear to be a problem BUT, if you look close at the final product (half shell of egg) it's not. Why? There will be quiz. Here's a clue: the recess has only four sides rather than five; it's completely open in side elevation ; i.e., there is no obstruction normal to the direction of part removal.
jack
Old 01-17-2012, 07:30 PM   #47
rabbit's Avatar
Delaware
Thumbs up
The real stiffener is that big "el" in each half of the roof that allows the vertically-challenged to stand upright along the centerline of the trailer. I still wouldn't be jumpin up and down in the middle of the roof no matter how good the bond of the glass across the seam inside or outside. All that red and blue bondo! Makes me think Rucio should be primer (or Burro) grey. But silver is nice too.
jack
burro
Problem with Bigfoot Floor Renovation Carl G Modifications, Alterations and Updates 13 10-29-2017 02:18 PM
Problem with Condensation Edward83burro Problem Solving | Owners Helping Owners 12 10-04-2011 10:28 AM
toiler overflowed and floor wet in dinette??? Dawn S Plumbing | Systems and Fixtures 3 08-08-2009 07:59 PM
New floor for Burro Myron Leski Modifications, Alterations and Updates 14 05-14-2006 04:29 PM
wet floor in bathroom, 13 ft. Scamp Garret Walther Problem Solving | Owners Helping Owners 13 04-12-2006 08:56 AM
