Burro Front Window Rock Guard Help Needed - Fiberglass RV
Old 07-27-2016, 10:57 AM   #1
Trailer: Researching Options
Kentucky
[IMG][/IMG]
The photos above show the front window of a Burro with the bracket for the rock guard attached. I just bought the trailer and the previous owner told me there was a leak along the top of the window. He had applied some tape across the top which that stopped the leak as a bandaid. I took the window out to reseal it. After removing the clamp screws inside the trailer, the window came out easily. Apparently the screws from the rock guard did not penetrate the fiberglass very well!
My question is, how to remove the screws? There is a cover or seal of some type that is blocking access to the heads of the screws! I guess this needs to be removed, but how?
In some ways I would like to reinstall the rock guard, although I have heard some people do not use them, so they can look through the rear window of their tow vehicle and see all the way through the trailers back window! I might want to do that for a while, since I am new to towing as well!!
BernieK is offline   Reply With Quote
Old 07-27-2016, 11:51 AM   #2
Bernie, your picture didn't post.
Old 07-27-2016, 07:11 PM   #3
Kentucky
Thanks Donna. I was attempting to post this while at work! I was interrupted and couldn't get back to it until the end of the day!!
Thanks,
Bernie
Old 07-27-2016, 07:21 PM   #4
tractors1's Avatar
Trailer: Escape 21 - Felicity
A bit hard to tell without more trailer body in the pic, but looks like the screws in question are part of a subassembly with the main C-shaped frame that needs to come out to access the screws.
Just a theory.
Charlie Y
Old 07-27-2016, 07:49 PM   #5
Kentucky
Just a theory.
I think you are correct. From what I can tell the window was installed, then the rock guard bracket was screwed through the window's rubber molding into the fiberglass. There was a ton of silicone or caulk of some sort along the top of the bracket.
The top photo shows a seal of some sort that is blocking access to the screw heads. In the photo is is a few shades darker than the rest of the C-shaped frame. It is also very hard. That is what I can't figure out how to remove.
burro
Front Window rock guard - its old and needs help Cathie Sadler-Pare Care and Feeding of Molded Fiberglass Trailers 4 10-24-2015 08:09 PM
Burro needs front window rock guard! Lfoxmont Care and Feeding of Molded Fiberglass Trailers 16 09-09-2013 06:50 PM
Help with installing front window rock guard mdboucher Problem Solving | Owners Helping Owners 5 05-11-2012 04:30 PM
needed, window rock guard Calud13 Classified Archives 5 04-29-2011 08:19 AM
Needed: Front Window Rock Guard Ray and Patty Parsons Classified Archives 0 05-20-2008 11:11 AM
