Burro Inspection - Home Assembled - Page 2 - Fiberglass RV
Old 08-27-2008, 08:30 PM   #15
Gina D.'s Avatar
West Coast USA
You can usually find Trim Lock (Brand Name) at any auto upholstery shop. Pick it up locally instead of ordering it.
I just bought 20 feet of it today for a project at work. It was all of 24 bucks.
Old 08-27-2008, 11:26 PM   #16
Trailer: 1960 28 ft Airstream
Trim lock>> is that the stuff that you can seal the seam outside with?
Pam
Pamela H is offline   Reply With Quote
Old 08-29-2008, 10:36 AM   #17
Hello,
I have the Burro (tito) in the driveway. It is just cute even with the caulking all over the outside.
I did get the first must fix news when I got home. I was pulling the original carpet and pulled the piece at the back just above the rear storage where the bolts for the spare tire are sticking through.
I found separation at the seam around 20" or so.
I am thinking of using that Formula 51? that the boat shops sell rather than fiberglassing. The Formula is a type of bondo, but I believe a bit more plastic.
Any opinions would be valued. I am going to try and do this in the next couple of days one way or the other (glass and resin). If I glass and resin, I will have to research on technique as I have only done this once many years ago.
I would also like to figure a way to add some more support in that rear section so the spare does not cause a future problem. I think this happened two owners ago. I was told he had a storage box mounted back there. It might have been too heavy.
The rear window definately needs new rubber. The outer seal although caulked along the top, may be okay, but the vertical strips separating the panes from the slider and the inner perimeter rubber have all shrunk beyond the ability to seal.
Any knowledge of where and which types to get would also help me to get this project in full gear.
All of the cushions will need to be redone soon, and there are a couple of pieces missing and others that appear to be not made just right. I will probably have to wait until I am fortunate enough to see one of your Burros to figure out how it is all supposed to be.
Oh yeah. On a previous discussion, I received great information about the trimlock molding and I have located a couple of companies that have it. Also, I will go to an auto upholstery shop today to see what they have. My Burro has a trimlock with 2 tabs on the inside and I was wondering if anybody elses has 1 tab on the inside of the trim.
I hope covering this much in one post is acceptable. Please tell me if not.
Thanks.
Mitchell
Mitchell is offline   Reply With Quote
Old 08-29-2008, 04:21 PM   #18
Thanks.
Mitchell
It's fine Mitchell, the only thing I did was take the SIZE out of it... so big it was making my eyes hurt.
I'd suggest if you have questions, to post one question per topic, otherwise things get all tangled up and you may miss the answer you seek. Plus it creates problem for "Search."
CONGRATULATIONS on the new-to-you trailer too by the way
Old 08-29-2008, 04:47 PM   #19
Trailer: Fiber Stream
Pam
burro
The new (to me) Burro, home Safely, Yeah! Jake General Chat 12 04-19-2010 11:46 AM
Trailer Inspection request - buyers check list Roy in TO Problem Solving | Owners Helping Owners 0 03-06-2010 12:38 PM
Project Burro- 1978 Burro 13 foot Scott B. Classified Archives 0 08-09-2009 11:19 PM
New Guy. Just brought home an '86 13' Burro Craig D Care and Feeding of Molded Fiberglass Trailers 11 07-01-2009 08:18 PM
South MN Scamp inspection? S&CMoody Classified Archives 1 03-28-2006 09:49 AM
