Okay the only real problem with the
Burro was the door latch not working properly. The plate to catch the latch was loose and I have taken it apart to bondo the holes where the latch screws in they were just worn and too big to hold the latch securely. In the process I have pulled the seal, not the rubber on the door but the vinyl? seal on the door way itself. It has cleaned up nice looking new with slight color fade. My question is... there was no adhesive of any kind on the seal except some really yellowed, must be silicone in the upper corners. When I put it back , should I use adhesive, if so...what? The outer seals are all in great condition, they are secure and in good shape, the very lower bottom right has come loose and I would like to know the BEST adhesive for this as well.
