2 areas seeking input for are:
A. Body side inlet/connections: I need help with knowing what hooks up to supply what on a couple of the inlet holes on the side of my
Burro.
Outside photo: a. The one to the left of the square power cord cover
b. Round one bttm left, 3 in. diameter
Inside photo: Inside view of a. in outside photo
B.
Electrical supply box: Never dealt with this kind of power inlet setup before so have a couple points I'd like help with. Guy who
sold this trailer to PO installed a 120 volt flourescent
light under the cabinet above the sink and tapped into the "push in" slots on the back of the outlet. As you can see the
light fixture only uses the neutral and black wires of the romex. Ground is just hanging there. The other end of this ground wire is attached to the ground bar inside the metal j box that was added. Is that anything I should be concerned with before plugging this thing into power? Have never plugged it in, been under frame off restoration.
Also, you can see where a stranded ground wire, think it's an 8 ga., has been added to the back of the j box and was attached to the frame before I ripped out and replaced the rotten floor. I figure this has to go back to the frame but in all others I have ever done this wire was not stranded, it was solid 8 or 6 ga. Thoughts??? Stranded OK or should I switch it?
Thanks much for any help. jd
