Burro wheel bearings - Fiberglass RV
Old 04-28-2012, 04:22 PM   #1
Trailer: Burro
Hi,
Just want to check on something:
My burro 13' only has outer wheel bearings, just wondering if they all come like this and how good are they or should I replace the hubs for the double wheel bearing one, the one with inner and outer wheel bearings?
Thanks
AJ
megatrack is offline   Reply With Quote
Old 04-28-2012, 05:14 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Are you sure there is not an inner bearing hiding behind the grease seal?
Old 04-28-2012, 05:50 PM   #3
Trailer: Burro
Thank you for the pic, that did helped a lot, ,You are right, it is like the pic except that there are no washer, the adjustable nuts is directly install on the bearing!
burro
Burro Wheel Bearings Landy Luther Towing, Hitching, Axles and Running Gear 1 11-18-2009 06:36 PM
wheel bearings thomas kaz Problem Solving | Owners Helping Owners 6 06-15-2009 10:53 PM
Wheel bearings JOE DRISSEL Care and Feeding of Molded Fiberglass Trailers 39 05-16-2006 10:57 PM
Wheel bearings. Legacy Posts Towing, Hitching, Axles and Running Gear 22 02-23-2003 04:18 PM
Wheel Bearings. General Chat 0 12-31-1969 07:00 PM
