Burro Window Seals - Fiberglass RV
Old 09-22-2016, 07:13 PM   #1
Scoboatn's Avatar
Trailer: Burro
Burro Window Seals
I am going to rebuild the windows in my 1982 13ft Burro. I need some help on where to get the seals. There are a few threads on this, but they don't address all the seals & some are confusing. Has anyone done a complete overhaul on these? Attached below is a picture I made of all the crossections. I thought this may help others also?
In order they are ....
1) Rattle guard
2) Spacer for screen window
3) Channel for sliding window
4) Seal for fixed window
5) Seal for sliding window
6) Seal on crossmember for sliding window.
Any comments on using plastic instead of glass for the replacement windows? My Burro has both right now, mis matched.
Thanks.
Scoboatn is offline   Reply With Quote
Old 10-06-2016, 12:56 PM   #2
YourHighness's Avatar
Trailer: Burro
Alabama
Window seals
HiCory. Have you replaced the screens on your Burro windows? Do you know the spline size? Mine are 36 years old and I'm not sure I trust the measurement I've made. .095"
Thanks.
YourHighness is offline   Reply With Quote
Old 10-06-2016, 06:01 PM   #3
Scoboatn's Avatar
Trailer: Burro
I have a screen pulled from the window I have apart now (the door window). The frame looks good so I am just going to replace the screen. Which dimension are you asking for?
Old 10-06-2016, 08:40 PM   #4
Trailer: Burro
Alabama
I'm wondering about the spline that holds the screen in the frame. I've tried one that is 1/8" diameter but it fits so tightly that I'm afraid that it's too large and I'll have to search for a smaller diameter spline.
Old 10-07-2016, 12:52 PM   #5
Scoboatn's Avatar
Trailer: Burro
Mine did not have a spline for the screen. The piece shown in the picture was used as a spacer (it was assembled with the flat side to the slide screen). The other side of the screen has the plastic screen clips that keep slight pressure on the screen frame and the window frame. Mine screen frame is large enough that it fits pretty good in the window slot and does not need a spline/channel for the screen.
Old 10-07-2016, 06:49 PM   #6
Trailer: Burro
Alabama
Thanks Cory. I guess that since my Burro is a 1980 that they must have later changed the way they attached the screen material to the screen frame. Maybe someone else has run into this issue. Good luck with your windows!
burro
Window seals & hardware for 76 Scamp tilt out windows Jenny W. Modifications, Alterations and Updates 47 04-21-2021 10:45 PM
Looking for window seals for Boler door window bomni Problem Solving | Owners Helping Owners 12 04-26-2012 04:51 PM
Window Seals Pamela McBroome Care and Feeding of Molded Fiberglass Trailers 6 05-07-2010 10:48 PM
Replacement window seals and gaskets Mila Care and Feeding of Molded Fiberglass Trailers 1 05-05-2008 09:56 AM
Window seals & hardware for 76 Scamp tilt out windows Steve Thomas Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
» Trailer Showcase
Bluey
72Bluey
Beachcomber
Bear
