Burst LP gas line. - Fiberglass RV
Old 12-05-2011, 09:44 AM   #1
Name: You can't call me Al
Trailer: SOLD: 1977 Scamp 13'
Massachusetts
Burst LP gas line.
I recently purchased a 13' 1977 scamp with a Suburban DuraTherm furnace.
I saw the temperature sensing bulb on the gas valve was broken off so I knew there was going to be some gas work before I had that working.
I rebuilt the gas valve so it works in manual-mode and I hooked the furnace directly to a gas-grill LP tank for testing in the back yard. It works GREAT!
When I reinstalled the furnace and hooked up to the existing gas lines, I smelled gas in the camper, so I went around with my bubbles trying to find the leaking connector, but I couldn't find one leaking.
I had to have my wife turn the valve on the LP tank on a little, then off , then on a little since the high-flow leak-check function of the LP tank kept shutting off the gas.
Eventually, I found a crack on the underside of the gas line, so I replaced the whole line. When I took the line out I see THREE places where the line was burst. This was a pretty good surprise.
I'm not quite sure what caused the line to burst in three places. All were on the underside of the tube.
The previous owner had a 30# LP tank and a really old-looking regulator. The regulator had a 1 inch diameter cylindrical opening with a plastic screw disk in it (for pressure adjustment maybe) which must have been filling with water because the spring and diaphragm below the disk were completely rusted away.
Could water have gotten through the gas regulator and into the lines and frozen? That seems like it might burst the line.
Anyway, it's got all new lines now and the furnace and stove are leak-free and working wonderfully now.
Some more cleanup and we'll be ready for some northern-MN snowshoeing over the Christmas break.
High resolution photos are at: https://picasaweb.google.com/1165069...JuNr5Ou7sL9lwE
AlanKilian is offline   Reply With Quote
Old 12-05-2011, 10:46 AM   #2
Trailer: 16 foot Scamp
I would cut the tube at the crack and look inside. More than likely the tube is corroded and the weak places blow out. The malfunctioning regulator could have been a contributor.
David
DavidSo is offline   Reply With Quote
Old 12-05-2011, 10:55 AM   #3
Raz
Raz's Avatar
Hi Alan and welcome to the forum.
It seems to me that with bursting in three places it must be water. I don't see how gas could cause more than one split. ??? Raz
Old 12-05-2011, 12:20 PM   #4
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
Certainly looks like a split caused by water freezing in the pipe, especially if it was on the bottom. Glad you were able to fix it it before it caused major damage.
Spanke
Trilliums Rock!
Old 12-05-2011, 06:28 PM   #5
Would be a good thing for all of us to check!
Trill136 is offline   Reply With Quote
Old 12-05-2011, 06:38 PM   #6
Trailer: 2007 Eggcamper
definitely froze and burst.
artspe is offline   Reply With Quote
Old 12-05-2011, 06:41 PM   #7
Dennis Clinton's Avatar
Trailer: Scamp 16'
Utah
Definately a water freeze split. When I checked out the gas line on mine, I found a kink where the line came in at the front of the trailer-appears to be done at manufacturer. Good thing the military disconnected the gas while the trailer was being used as a loaner.
Dennis
Dennis Clinton is offline   Reply With Quote
Old 12-05-2011, 07:21 PM   #8
Massachusetts
Thanks everyone. What a wonderful group you are.
Expert analysis in a flash!
It's sure going to be fun restoring this with your help.
I bet this will be my first Egg and I'll think back fondly on repairing each little bit.
Old 12-05-2011, 08:07 PM   #9
Trailer: Trillium 4500 1977
Quebec
When I bought my Trillium 4500 last summer, there was enough water in my gas line to make the gas bubble up, so stove top flames were pulsating and I could hear a strange noise out of a brand new gas regulator I installed to replace the original one (1977) on my Trillium. I disconnected the gas lines at the lowest point and purged them with compressed air. I collected half a cup of oily water.
I know brand new gas tanks must be purged to prevent water to contaminate the propane content. Propane should not contain any water. I can ony think of a cylinder that was not purged properly or propane hoses that were disconnected and got contaminated with rainwater or melting snow.
Another possible source of contamination is a defective gas regulator.
Martin J. Qc Canada
lamimartin is offline   Reply With Quote
Just gas or gas/electric water heater? Feedback wanted. Bryan L. Care and Feeding of Molded Fiberglass Trailers 15 09-15-2010 09:11 AM
Moving a Gas Line Connection/CO HAZARD (furnace)? Suzanne P. Problem Solving | Owners Helping Owners 7 07-13-2007 12:24 PM
Gas line Problem or Not? Gerry Problem Solving | Owners Helping Owners 17 05-15-2007 12:05 PM
