Butyl tape question - Page 2 - Fiberglass RV
Old 09-27-2012, 06:26 PM   #21
Originally Posted by rabbit View Post
I didn't use the word "fibrous" either. Fibrous is straw in bricks or milled fibers in resin. I did use the word filament as in I can really stretch this chewing gum into long filaments. Ed, you've sort of bulldogged this one so I yield the floor and the thread and the nomenclature and the qualifications and the visual vs. tactile recon to you, Sir.
jack
Jack sorry I switched filament to fiber as in sewing filament is common for very thin fibers.... but realize what you mean and how it applies to chewing gum as well.
Old 09-27-2012, 07:24 PM   #22
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
No worries, Carol. I guess the important thing is that everyone be able to identify the genuine article.
jack
Old 09-27-2012, 08:16 PM   #23
dylemma's Avatar
I asked for Butyl tape, I confirmed with RV store guy that it was Butyl tape and my bill says Butyl tape.
Name:	IMG_0156 (600x800).jpg
dylemma is offline   Reply With Quote
Old 09-27-2012, 09:02 PM   #24
Ok so here is the link to the stuff the Camping World sells and funny enough its grey and its doesnt appear to have a bit of a shiny .... hummm. Manufacturer of their stuff is : Dicor Corp - but if you go to thier website they call it Buytal Putty Tape and claim it to be non harding. But as we heard the real stuff should only be white or black how do we know what the heck we have....... confusing.
Old 09-27-2012, 11:51 PM   #25
dylemma's Avatar
and it gets 5 stars from LAMONTE MONNELL from WEEKI WACHEE, FL
How can you go wrong. Looks just like the stuff I bought.
Old 09-28-2012, 04:37 AM   #26
Ed Harris's Avatar
Well if this doesn't help make everything clear as mud.....
Butyl Tape For All Applications-Find What You Need Fast!
Evidently it does come in many exciting colors and as Dylemma shows theirs is from Dicor who makes the best Lap Sealant I just don't know what to think now?
All I do know is what I have seen myself and I would want to feel that I had the real thing as the putty is just not as tenacious a sealant from my experience and will indeed dry out as I have seen when removing older puttied fixtures.
As a friend of mine often says "I now Plead and Drink the Fifth" on this one!
Old 09-28-2012, 05:17 AM   #27
rabbit's Avatar
Delaware
Didjaever think that it could be the proportions of something to something in something that determines the properties that are sought as desirable for a particular application? I think the key is butyl content. The five dollar vent tape kit from Camco is not "stretchy" compared to the stuff I used on my rear window. When I mention filaments I mean you can pull this stuff until you've got a "string" 18" long. The Camco stuff will break and leave little strings a 1/2" long.
The stuff I used on my rear window was 1) grey in color, 2) shiny in appearance, 3) stuck to fingers unless moistened, 4) squeezeout could be removed by "scoring" around flange with a plastic dinner knife and pulling off. 5) was not unmanageably sticky and didn't require a solvent to remove or the "self to self" removal described elsewhere, 5) excess was harder to remove after heating by the sun and tended to stretch into impossibly long filaments, 6) "bounced back" when squeezed (like a rubber ball).
I have also used the Camco tape previously. I found that: 1) squeezeout could be removed by method above but it didn't stretch and become more sticky with temperature increase, 2) had an oily feel, 3) a small ball could be elongated by rolling between the palms much like modeling clay, 4) DID NOT evidence the "rubbery" bounceback when squeezed.
I'm thinking from I've seen (not a great deal) and heard here that there are number of products that nominally fall in this category of butyl tape. Apparently some are a linseed based putty and the "butyl" is only in the label. It also appears that there are some automotive sealants for glazing that come on a roll and have a separator but are a bit too tenacious, difficult to work with and difficult to remove for our purpose (bedding thru-hulls, sealing window flanges).
I wish I could find the shipping label for the roll I bought in 2010 but I can't. To the best of my recollection, a 25' roll was nearly 30$. That could possibly be one indicator of quality and the stuff that's 6 bucks for a 25' roll likely is an oil-based putty which hardens over time. At C World, all bets are off as far as value for payment tendered. It really is sad that the world is full of stuff that's no good and stuff that's too good and some that's just right and it all has the same label!
jack
Old 09-28-2012, 05:25 AM   #28
Ed Harris's Avatar
What Jack Said!
Old 09-28-2012, 05:47 AM   #29
cpaharley2008's Avatar
Either one will work in sealing around your windows so I'd not worry about what it is called, I have used both and seen little difference. I'm sure what is used in today's trailer manufacture is probably the least expensive one, not necessarily the best one.
Old 09-28-2012, 11:03 AM   #30
Thats easy for you to say you have a roll of what you know to be the right stuff!
Hard to believe that actually buying and figuring out the right stuff is so difficult. I know I went to a fair bit of effort to get the roll I have now only to discover here that it may be questionable as to whether or not it really is the *real* right stuff.
The suggestion they are both usuable is probable not fair off providing what you have is in fact sticky & streaches out well - the question is more likely how long will it last 10/15 years? vs 20/25 years? either way I am willing to bet it will last longer than caulking
Old 09-28-2012, 12:47 PM   #31
Trailer: Former CT 13 Owner
Connecticut
I know it will last longer than I do.
....and a river runs through it.
Joseph Kristan is offline   Reply With Quote
Old 11-19-2012, 06:48 PM   #32
Trailer: Casita 17'
pictures of sticky butyl tape
pbase.com/mainecruising/butyl_tape
(sorry you have to paste the link)
yolofitz is offline   Reply With Quote
Old 11-19-2012, 07:24 PM   #33
Try a decent marine supply store. The stuff we use on yachts is grey, about 1/2 to 3/4 inch wide, maybe 1/8" thick, stretches to eternity, isn't gummy to handle but sticks to anything dry and clean like crazy once the fasteners are tightened, and remains flexible and adhesive for a long, long time.
I've used everything clear of nuclear power trying to get old butyl tape to let go of the fiberglass, and have even been known - very occasionally, of course - to utter a mild oath or two when trying to convince it that it has really had its day after 35 years under a piece of deck gear subject to forces in the 1000's of pounds...if it doesn't leak there, it'll seal the Trill's windows just fine...
Rabbit's long post pretty well nails it...
Richard Hayes is offline   Reply With Quote
Old 11-19-2012, 07:49 PM   #34
Direct link: Need Butyl Tape ?? Photo Gallery by Compass Marine at pbase.com
Old 11-19-2012, 11:08 PM   #35
FTTRV's Avatar
Trailer: tp
Look at this tape. I sell it at Fiberglass Travel Trailers RV
Old 11-20-2012, 05:30 AM   #36
Ed Harris's Avatar
Looks like old school Putty to me,not Butyl?
Old 11-20-2012, 08:08 AM   #37
rabbit's Avatar
Delaware
+1 what Ed says. The lateral creases on the inside of the roll. No sheen to the surface. That video from Donna tells the story on stretch potential in the real McCoy.
There are volatiles in both types I think. I keep what's left of my roll of butyl double bagged in Ziploc bags to try to make them stay in there. I leave the Camco stuff exposed to the air to see how long to rock hard. Doesn't seem fair to Brand X.
jack
Old 11-20-2012, 09:02 AM   #38
Thomas G.'s Avatar
For the OP - be aware that there are two similar products sold side by side. The butyl tape is extremely sticky and will stretch into hair fine stands. The similar putty is less sticky and does not pull into strands without breaking. You want the butyl.
Old 11-20-2012, 04:35 PM   #39
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Good grief.
Butyl tape DOES come in more than one color, folks...The word "butyl" denotes only that there's butyl rubber in it and says nothing about color etc.
Here are THREE DIFFERENT COLORS of Butyl tape:
Putty sealants and Butyl sealant tapes by Elixir Industries
Both the O.P.'s original posting and Deb and Chuck's pic above are butyl (rubber) tape, if so named by their maker(s), and both are very commonly sold at body/RV repair shops.
The black version is less commonly sold due to its propensity to stain surfaces it contacts.
Francesca
H
Old 11-20-2012, 07:37 PM   #40
Yup Francesca I think we got that a while back. ;-) The basis of most of this thread and the main issue is that various companies (including some RV & Boat shops and body shops) are selling a product they call Butyl tape and it looks a lot like the Butyl tape, you have posted & what the OP posted the photos of but its really Butyl putty (which is a little less sticky). Trying to find an easy way to tell which is which so we all get the right *real* sticky stuff. Not as easy as it sounds! apparently. But I think the answer is to finger test it. If it doesn't *seriously* stick to your fingers it Butyl putty not tape.
Butyl Tape ?? Harvey Problem Solving | Owners Helping Owners 18 09-08-2017 10:09 PM
Butyl Tape...but this is different...no really Craig D. Thompson General Chat 16 07-06-2013 03:19 PM
Butyl tape vs. butyl caulk- newbie looking for input Jason, M Problem Solving | Owners Helping Owners 9 08-11-2008 02:57 PM
Just Butyl Tape Or More ?? mitch Problem Solving | Owners Helping Owners 18 05-28-2007 08:20 PM
Using Butyl tape Gary Little Problem Solving | Owners Helping Owners 2 03-01-2006 08:34 PM
