Butyl Tape, Silicone and sealing - Page 7 - Fiberglass RV
Old 11-19-2010, 09:59 AM   #85
Raya's Avatar
I started to write this yesterday, but then it sounded so ..... vague... that I erased it and didn't post. But, I'll try!
On the silicone: If it's clear (probably dirty clear by now), it's probably silicone. There are a couple of other clear caulks, I think, but every time I've seen clear caulk on a fiberglass camper or boat it has been silicone.
If it's white, it could be silicone, but also has a good chance to be one of a number of other caulks.
Texture: Sure, all caulks are resilient, but silicone is just..... ruuuubbery. This is the part where I stopped typing yesterday. Because of course most caulks could fit this description. But silicone is really rubbery/stretchy. You think you have it off your trailer, it's ten feet away, and then it bounces back and sticks It's like the evil version of a Knox Blox (you know, those hardened Jello candies).
Now you see why I didn't post this yesterday. If I could see/touch the caulk in person, I could tell you in two seconds whether it was silicone or not, but in words it's hard to describe.
There also seems to be a cruel inverse relationship: The more a PO piled on the caulk, and the bigger the globs are, the more likely it is to be silicone
Raya
Old 11-19-2010, 10:43 AM   #86
cpaharley2008's Avatar
Thanks Raya,
For taking the time and thought in formulating your response. If we ever meet at a Rally I'd like to blindfold you and watch you do your stretch test on some roofs- just kidding. Thanks again
Old 11-19-2010, 11:23 AM   #87
Trailer: '73 Boler
Originally Posted by Tim D. View Post
A local rv person recommended Vulkem for sealing around windows and vents. He swears by the stuff and it is cheap--less that $5/caulk-gun-tube at Jerry's, our local home improvement center in Eugene.
http://www.tremcosealants.com/commercial/p...mp;product_id=4
Vulkem 921
Product Description:
Vulkem 921 is a one-part moisture curing, gun grade polyurethane sealant. Vulkem 921 is low modulus, durable, flexible, and offers excellent performance in moving joints. Vulkem 921 does not require a primer on most construction materials.
Basic Uses:
Vulkem 921 is an excellent general purpose sealant designed for use in precast, masonry, window and door frame perimeters and similar types of construction joints. Vulkem 921 is also suitable for continual immersion in water with the use of appropriate Vulkem primer. Vulkem 921 is designed for exterior and interior use.
Does anyone have experience with it? I plan to test it around a vent on the roof before sealing around the windows of my 1986 Bigfoot.
Just as a follow up to this, Tremco has a very user friendly website and I was able to get a free sample of this product sent to me for trial (sent them to my office. I will keep everyone posted on the results. I don't want to unleash a barrage of "sample requests" onto Tremco from fellow fiberglassrv owners, but the two tubes came in a week and if it works, I will definitely order some to finish off the windows. I'm going to test it on my roof vent, that seems to have a small leak.
Regards all
Kyle
astroboy is offline   Reply With Quote
Old 11-21-2010, 08:01 AM   #88
In research for FlexiSeal it states it is a silicone base caulk. I thought this entire discussion was on the merits of not using silicone on fiberglass? Now I'm confused, after Butyl tape. what do we use to seal the edges?
PRO-SPEC FLEXI-SEAL WINDOW & GLASS SILICONE SEALANT
Old 11-21-2010, 08:58 AM   #89
The point is, you don't seal the edges of the windows.
Old 11-21-2010, 10:59 AM   #90
Scamp does.
Bill K
Old 11-21-2010, 12:03 PM   #91
In response #4 on first page, after installing butyl tape, the owner then seals the edge with Flexiseal. which according to the manufacturer is a silicone base caulk? So do we need to use a different sealer after using the butyl tape?
Old 11-22-2010, 03:35 PM   #92
Joe Z's Avatar
New River AZ
I use something that i purchased in Lowes called "POLYSEAMSEAL" it's an adhesive/caulk and contains no Silicone and comes in "white" I used it for a few years on various small applications and have had no side effects yet. I also used 3M 5200 which is excellent but it is not removable which limits the use of it.... 3M has something that is removable and i forget the number on it and it contains no silicone..... I believe it's 4200 but not sure?
Joe
Old 11-22-2010, 04:09 PM   #93
Originally Posted by Bill K View Post
Scamp does.
Bill K
Interesting, I've yet to see any molded trailer where caulk has been put around the outside of windows by the manufacturer. Guess I need to pay more attention. I know Scamp didn't on my 1988, but that was nearly 23 years ago and I suppose things have changed since then.
Old 11-22-2010, 04:24 PM   #94
Mine is a 2009 and I went out and looked at the windows before saying it was that way. LOL
Bill K
Old 11-23-2010, 08:19 PM   #95
Myron Leski's Avatar
Trailer: 19' Escape
NM
Sealing around the outside edges of a window makes absolutely no sense to me at all. I have removed and recaulked all my eggs' windows using butyl tape and nothing else, and cannot see the logic of additional edge caulking. No leaks. Always a clean, simple to do job.
Where the butyl squeezes out the exterior edge if the application is too thick, it gets easily trimmed off with a putty knife. In any case, the butyl is a barrier where the gaps in the inner egg shell face the metal window frame. That's where any water gets blocked. What does added outside edge caulking accomplish, other than creating an ugly, visible bead?
Myron Leski is offline   Reply With Quote
Old 05-19-2011, 01:52 PM   #96
Originally Posted by Con View Post
I also drilled out every pop rivet and replaced them with 10-24x 3/4" Truss Head Stainless Steel bolts (Total cost $6.00 for 100, the SS Accron nuts for the inside were a bit more exspensive) and used white plastic washers under them on the out side.
Hey there Con. Thanks for ALLLLLL the info you've provided. I am pretty new the board, and owning MY FIRST BOLER!!!
I am excited and noticed the websites you posted from Bolt Depot - Nuts and Bolts, Screws and Fasteners online .
My question to you is... Can you specifically tell me which screws, nuts, and washers to buy?
I have a 78 Boler but don't exactly know how long and thick they should be...
So far I've gathered you bought the:
Stainless steel 18-8, Diameter: #10-24, Product # 6929, 3/4 (x100 units)
Then I got lost...
I gathered that you used a Stainless steel 18-8 Cap Nut but I don't know the size...
I assume its Product #2544, Size 10-24 ? (x100 units)
And I also didn't know which washer specifically to buy.
And why did you use the length you chose? Did you pull out a Rivet, and measure it from that?
I figure there is a distance between the Outside of the FG and the Insolite.
I have all original interior so I wonder if I can just buy the stuff as you.
Thank you!
Manoel
closefan is offline   Reply With Quote
Old 05-26-2011, 06:20 PM   #97
Gumpit's Avatar
Trailer: 1978 Trillium 4500
Massachusetts
I just replaced the roof vent on my Trillium. I used the Butyl tape and it squeezed out nicely when I screwed it down. I would still like to overkill it and seal up the edges with something as well as the screw heads. Is Flexiseal the preferred choice still or the Marine type stuff. 4200 or 5200? Where can I get the Flexiseal? The RV place couldn't find it and I didn't see it at West Marine either. Thanks Randy
Gumpit is offline   Reply With Quote
Old 05-26-2011, 08:00 PM   #98
Joe Z's Avatar
New River AZ
I just had somebody on another forum that is a big boat fixer and he recommended "Lifecalk Sealant" as one of his favorites for rivet caps and small jobs like that....The 3M 5200 is very hard to remove.... the 3M 4200 is also a good removable choice....
Has anybody on here used LifeCalk that can give there experiences with that product
Joe
Lifecalk:
Amazon.com: lifecalk: Sports & Outdoors
Butyl tape: What width and thickness to order? Raya Care and Feeding of Molded Fiberglass Trailers 9 08-21-2015 01:14 PM
Butyl tape - HOW TO APPLY Barry Konkin Problem Solving | Owners Helping Owners 9 11-07-2008 10:02 PM
Butyl tape vs. butyl caulk- newbie looking for input Jason, M Problem Solving | Owners Helping Owners 9 08-11-2008 02:57 PM
Just Butyl Tape Or More ?? mitch Problem Solving | Owners Helping Owners 18 05-28-2007 08:20 PM
Using Butyl tape Gary Little Problem Solving | Owners Helping Owners 2 03-01-2006 07:34 PM
