Cabinet & Drawer latches - Fiberglass RV
Old 01-15-2013, 10:12 PM   #1
Trailer: 99 Scamp 16
Idaho
Anyone have any modifications to keep drawers and cabinet doors from coming open during travel especially on washboard roads or rough highways? The roller latches seem to not want to hold the doors shut. Thanks!
camper1887 is offline   Reply With Quote
Old 01-15-2013, 10:28 PM   #2
Lil M.'s Avatar
Trailer: '84 13' Scamp & '14 homebuilt Benroy Teardrop
I use bungee cords to hold the cupboard and closet doors closed when I'm travelling. I can lock my one drawer, so I don't have a problem with that...unless...of course...I forget to lock it.
Lil M.
“When one tugs at a single thing in nature, he finds it attached to the rest of the world.” ― John Muir
Lil M. is offline   Reply With Quote
Old 01-16-2013, 12:26 AM   #3
Joy A's Avatar
Here's my solution to the 3 doors over the kitchen in my Scamp 13.
The utility/silverware drawer has never come out. I use a bunge cord for the closet door.
Joy A. & Lily
and "Puff", too
No. Ca. Sierra Foothills
Old 01-16-2013, 01:14 AM   #4
Trailer: Casita 2001 spirit
I am in the process of putting new doors on all the cabinets (My Casita arrived with none ( ) My pal came up with using the latch like on the old style double hung windows, we have to shim the receiver that mounts on the cabinet to match the door thickness but these when closed should hold up to any road bump. Home Depot $2.87 +/- they come in white enamel. I am going to use the Casita push button knob on my one drawer - $8 plus S/H. I found the replacement latches that were originally on "Eggbert" but they are $12 & up @ overheads, the kitchen doors used the "Bulldog" hole in the fiberglass, plug on the door & then you would need a pull. Using my inexpensive fix for now. Hope this helps.
partslady9 is offline   Reply With Quote
Old 01-16-2013, 05:48 AM   #5
Ian G.'s Avatar
Here is my solution
Old 01-16-2013, 09:19 AM   #6
Philp-it RV Cabinet Latches are a small easy solution for problem doors all be it a bit pricey.
Old 01-16-2013, 10:04 AM   #7
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
I used a 1/4" dowel rod with rubber bands when I had my SCAMP.
Place the rod behind the top of the door pulls and slip the rubber band over the door pull.
Name:	rod with rubber bands.JPG
Old 01-16-2013, 10:19 AM   #8
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Attachment 54411
Slick idea. You could use shock cording instead of rubber bands.
Shock Cord - 1/8 Inch at REI.com
Old 01-16-2013, 10:28 AM   #9
I have had the same problem. I have not fixed it yet, but I have been tempted to go back to the latches my previous RV had which were a positive latch system and worked well. See some samples below. The last picture is one that is meant to be a concealed latch that is meant to work with your existing cabinet knobs. Just search on "cabinet hardware RV" if you want more options. Let us know what you choose and how it works out.
ericw is offline   Reply With Quote
Old 01-16-2013, 10:30 AM   #10
Thomas G.'s Avatar
Here is the solution.
Old 01-16-2013, 06:25 PM   #11
On our overhead cabinets I put a eye bolt at each end next to the cabinet door, then slide a wood dowel through them, across the doors, with a hairpin type clip through a drilled hole on each end of the dowel. Closet door has a plain old hook & eye to keep it shut while traveling.
Old 01-17-2013, 09:50 AM   #12
Sue and Henry's Avatar
Name: Sue and Greg
Trailer: 1982 Burro 13 foot and a 2015 Casita Spitit Deluxe 17 ft.
I added some doors to my burro and replaced a broken latch. I used the top left one in Eric's post. It came close to matching the original latches and works great.
Sue and Henry is offline   Reply With Quote
Old 01-19-2013, 08:31 AM   #13
Pam Garlow's Avatar
Trailer: U-Haul 1985
Attachment 54411
Slick and simple solution, Kevin.
Small enough to easily store and probably a great back scratcher too! (I love multi-use tools!)
Old 01-19-2013, 09:12 AM   #14
Paul Chet's Avatar
Trailer: Vixen Motor Coach
Push Button Cabinet Latches - C-Quip
These are a little costly but I first saw them on our boat at work. We dive from it frequently and in close quarters, it has been quite functional and aesthetically pleasing.
This is a generic link so look up "push button latch" for better local results - I just used this link so you can see the latch is flush when not in use and completely out of the way. You push it in, it clicks, the middle pops out, then you pull the extended portion to open the door. When you are done, you push it in until it clicks when flush, and its out of the way again.
I have torn the pockets off several pairs of cargo pants (what I typically use when we camp in the egg) and have finally bought some latches like these ... now I just need to install them!
Paul Chet is offline   Reply With Quote
Cabinet latches for my Boler 17 BCDave Classified Archives 1 06-17-2011 10:18 PM
Cabinet Door Latches CliveAlive Problem Solving | Owners Helping Owners 8 01-25-2010 07:20 PM
Trillium Cabinet Latches jimliston Modifications, Alterations and Updates 7 01-21-2009 10:38 PM
Casita Cabinet Latches Legacy Posts Problem Solving | Owners Helping Owners 1 08-06-2003 06:15 PM
cabinet latches Legacy Posts Problem Solving | Owners Helping Owners 0 06-01-2003 11:37 PM
