Cabinet Door Latches - Fiberglass RV
Old 01-24-2010, 11:00 AM   #1
CliveAlive's Avatar
Trailer: Boler American (#3104)
I'm just finishing the new doors for all the cabinets. Nothing fancy, just polyacrylic satin clear varnished plywood.
Question is, what are the best fasteners to use?
Scamp has these
http://shop.scamptrailers.com/p-324-cabine...ller-catch.aspx
but I'm not sure I can make them work unless I tab in some re-inforcement inside the cabinets to mount them to.
I know Pete has some slick magnets.
Are the original chrome latch style of handles still available anywhere?
Has anyone used velco tabs and would that work and be strong enough?
Thanks for any replies.
Old 01-24-2010, 12:09 PM   #2
Try these Magnetic_latches
George.
Old 01-24-2010, 12:36 PM   #3
Raya's Avatar
[I had originally said I had seen them at Vintage]
Edited to say "Oopsie, it wasn't Vintage that had them!"
And now I can't remember where I did see them.
But, from a quick search, here are very similar ones to what I was talking about. The second set is similar in style to the ones on my Boler, with the two "feet" that extend near the latch end of the handle for fasteners. These are completely surface mount, with the receptacle side varying in height to match your door thickness.
http://www.rvpartscenter.com/ProductDetail...=50&CID=380
and
I know I've seen similar ones elsewhere also, maybe in silver.
Raya
Old 01-24-2010, 08:13 PM   #4
peterh's Avatar
Never really liked the Scamp latches. I replaced them with strong magnets I screwed to the frame of my cabinet doors:
I installed a push-button latch for the center door of the cabinet I built for the back of the trailer over the dinette.
They are a smaller diameter pushbutton than the ones Casita uses, and I think they're a better fit, aesthetically, for the trailer. Got them from here. Like them a lot. Their only downside is they're designed for thicker cabinet doors and frames, so you have to "build up" the door frame and door in the spot where you put the latch to match that of a traditional cabinet doors and frames. I did this using a couple 1/4" blocks of wood glued to the inside of the door and cabinet.
Old 01-24-2010, 09:45 PM   #5
Unhappy
Has anyone used Velcro tabs and would that work and be strong enough?
The Fiber Stream has lightweight sliding doors for the upper kitchen cabinet. A previous owner installed Velcro tabs to hold them closed during transit.
The fuzzy loop part (1/2" x 1") is rivited to the side of the cabinet in the middle of the curve of the opening. Half of it hangs in front of the opening facing in.
The hard hook part (1/2" x 1/2") is glued to the face of the door panel facing out.
The one for the aft slider keeps ripping the loop part out of the rivit. The hook & loop parts stay fastened to each other. I think the rivit was installed too close to the edge of the material.
Old 01-24-2010, 10:23 PM   #6
Raya's Avatar
I guess it would depend on what you had inside the cupboard, but you wouldn't want something pushing a hinged door open "underway."
The Velcro™ types I've used that would hold a hinged door that strongly would not be all that fun to use on a regular basis, in my opinion (the double hook type). They are a lot more of a pain to open and close then a latch handle.
It would be different on a sliding door, because the force of objects against the doors would be outward, and there is a track to hold them in place. So the latch/velcro/whatever is only holding the door from sliding sideways, not holding the contents in. There's more force of contents on a hinged door trying to open it.
Now maybe I'm being too cautious because of my background on sailboats. There, you want to know you could turn the boat upside down and shake it and have everything stay in place. I know it's not that severe in an egg though.
I agree that the original latches on the Bolers/Trilliums are not all that satisfying, architecturally
There are some nice latches and catches in boating catalogs, although they are more expensive and heavier, as a rule. But you might get some ideas from something like www.westmarine.com
Raya
Old 01-25-2010, 12:30 AM   #7
Alf S.'s Avatar
Hi: All... Vintage Trailer Supply has the same style of dual pinch catch here that were used on our '77 Boler. They work on 5/8ths. thick doors I think.
Old 01-25-2010, 04:33 PM   #8
Trailer: 13 ft Perris Pacer
The ones Raya posted are the way to go. They are also referred to as positive latches if that helps in your search.
Angelo F. is offline   Reply With Quote
Old 01-25-2010, 08:20 PM   #9
CliveAlive's Avatar
Thanks everyone very much for your replies.
Food for thought!
Trillium Cabinet Latches jimliston Modifications, Alterations and Updates 7 01-21-2009 11:38 PM
Cabinet door latches Ian R Modifications, Alterations and Updates 7 05-23-2007 10:35 AM
Cabinet door material Isaac M Problem Solving | Owners Helping Owners 6 06-30-2006 03:01 PM
Casita Cabinet Latches Legacy Posts Problem Solving | Owners Helping Owners 1 08-06-2003 06:15 PM
cabinet latches Legacy Posts Problem Solving | Owners Helping Owners 0 06-01-2003 11:37 PM
