cabinet doors hard to open - Fiberglass RV
Old 08-23-2018, 06:03 PM   #1
Trailer: PARKLINER
I have a Park Liner and the interior wooden storage doors that have the round roller spring loaded hinges, a few are very hard to open. Is there a way to adjust these for least tension (I see no slots in the mounts to adjust) the springs are just too tight.
Do I just need to replace? Or do you just file down the fiberglass opening at the point where the latch is ?
Billreedred is offline   Reply With Quote
Old 08-23-2018, 09:28 PM   #2
Trailer: Trails West
I don't own a Parkliner and it would have been helpful if you had posted a photo of the catches you have.... however if it is the type of cabinet catch where the door has a metal piece that is bent into a modified V shape with the V bent out rather like an arrow shape then that is easy enough to adjust. Just use pliers to gently squeeze it so it is slightly narrower across the width. Don't be too aggressive, do a little bit, test, if needed a little more. You don't want the doors to come open. But of course you can spread it back open a little if required. If the shape gets a little too long then the roller side needs to be slid further back.
Old 08-24-2018, 10:04 AM   #3
Trailer: PARKLINER
I will take a picture and add to my problem question, later today
my roller just slides over the fiberglass lip of the opening
Old 08-24-2018, 11:23 AM   #4
Trailer: PARKLINER
Old 08-24-2018, 11:29 AM   #5
Filing down the edge of the fiberglass is probable best.
I added spring loaded struts to hold the doors up.
They also hold them closed, so I removed a few of the rollers.
wc
Old 08-24-2018, 11:30 AM   #6
I think you will find that the screws go though a SLOT and not a circular hole. But that is hidden by the washers. Loosen the screws a little and the latch will likely slide back and fourth a little. If that does not work you need to just relocate the latch. That can be a bit tricky. I just had to do that when I cut the opening in the fiberglass to make the cabinet a little wider.
Its a very cheap latch so finding a better quality type might be a idea also.
Old 08-24-2018, 11:50 AM   #7
Trailer: PARKLINER
Thanks good idea
Old 08-24-2018, 05:35 PM   #8
If you need to move the screw holes you can fill them up with some of the kneadable epoxy putty stick material. That stuff dries nice and hard and sets quickly, but give it an extra day to reach full strength for this kind of task. That will allow you to drill a new hole much closer to the original than you could if you did not use such a strong filler in the original hole. Hardware stores carry this item.
Old 08-24-2018, 07:05 PM   #9
tractors1's Avatar
Trailer: Escape 21 - Felicity
I replaced that type with magnetic latches. Several sizes and strengths are available.
https://www.amazon.com/Strong-Magnet...h+for+cabinets
Charlie Y
Cabinet doors or No cabinet doors? openthegates Problem Solving | Owners Helping Owners 29 07-28-2016 04:43 PM
Boat Hatch doors to replace Burro Cabinet doors. Tommy Gun Modifications, Alterations and Updates 3 10-09-2015 06:44 AM
Doors, Doors and More Doors + Vents Bob Miller General Chat 0 01-19-2015 09:34 AM
Mod keeps swing-up overhead cabinet doors open peterh Modifications, Alterations and Updates 10 03-09-2007 12:08 PM
