02-20-2010, 10:32 AM
Trailer: 85 U-Haul 13 ft
Hello, I have a 84 13' ct uhaul camper. I am missing all of the liners. I was wondering if anyone has lined the areas with anything and if so with what and how. Also Has anyone mounted a tv anywhere in the camper? The walls are thin not sure they would hold any ideas would be helpful. Thanks Steph
02-20-2010, 10:24 PM
Trailer: U-Haul 1985
For now, I just use plastic bins in the storage compartments. Works fine.
As far as mounting the TV, If you pick a wall that you can get to the other side of, such as the upper cabinet or the closet, you can reinforce the mount from the back.
02-21-2010, 05:37 AM
Trailer: 16 ft U-Haul VT
While we have a 16' UHaul, I thought that I might add here that we use a 19" TV on a mount that we take off during travel. We used to use a small undermount TV, but we often like to watch DVD's in the evenings and just could not see the small TV well enough.
1988 Bigfoot Silver Cloud, "The Egg Carton"
02-21-2010, 05:56 AM
Trailer: 1984 U-Haul / 02 Mazda pick up
We have noticed that our 84 CT has a lot more storage space without the liners. Not as pretty inside the lockers, but a whole lot more useful.
03-15-2010, 09:30 AM
I went ahead and lined the cabinets and closet with reflex looks much nicer. The tv problem...I thought I would just set it on the covered sink but a glare if in bed. Turns out the tv is light enough to hang on the bed wall with two suction cup hangers. It stayed securly for the two hour trial and had to pull suction cups still stuck to the wall off.
Steph
05-23-2011, 10:06 AM
Trailer: uhaul, 84, 13CT
Massachusetts
Steph
Hi: I have a similar problem, no liners. please- What is "reflex"? It may make my unit alittle more pleasant.
05-23-2011, 01:38 PM
Massachusetts
Originally Posted by Frederick L. Simson
Thanks, It looks like a good product and something I can work with. h.mike
05-23-2011, 07:49 PM
Trailer: Uhaul CT-13
Ohio
05-23-2011, 09:19 PM
Trailer: 1988 Perris Pacer ('Bean') / 2004 Element
And Mike, here's what that Reflectix looks like as a liner.
05-23-2011, 09:21 PM
Opps, that last pic showed my new edging---here's an overhead with liner.
05-23-2011, 09:27 PM
I built an entertainment center for the TV, DVD & satellite box. The dinette is a permanent bed so I mounted it in the streetside rear corner. Attaching it to the window frames with "L" brackets. I also used some aluminum stock as a brace from the lower cabinet up under the shelf.
Joy A. & Olive
and "Puff", too
Fulltime
2019 Ram Longhorn
05-24-2011, 01:07 AM
I put reflectix up on the vertical components (including the wall/ceiling of the kitchen cabinets over the stove and my closet). You can put shelf liners on the bottom of the cabinets, or carpeting, or even wood shelving will give you a smooth clean surface. I thought I wanted liners until I actually saw them installed in a trailer. You lose a LOT of storage space with them.
05-24-2011, 03:19 PM
Trailer: 74 Boler 13 ft / 97 Ford Aerostar
Steph
hi Steph,
We mounted our TV and DVD player on the underside of the cupboard over the kitchen counter. On the Boler, I used a piece of shelf bracket anchored from the centre metal post to a window frame to support the bottom so it did not jiggle around while driving. No holes in the trailer wall. The position was excellent and gave a good view from both the front and rear bunks. On our new trailer, we have installed the same arrangement in the same location, which also works great. Pictures are on this thread in the 4th post: http://www.fiberglassrv.com/forums/f56/reno-s-gone-wild-exterior-access-doors-42298.html
Later,
Rick G
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Television Needed
Bruce Thomas |
33 |
02-17-2012 04:18 PM |
One Liners
Donna D. |
Jokes, Stories & Tall Tales |
2 |
12-21-2005 10:39 AM |
television cable
Legacy Posts |
6 |
03-31-2003 01:32 AM |
One liners
Legacy Posts |
17 |
02-13-2003 02:01 PM |
television needed
Jayson Jones |
0 |
01-01-1970 12:00 AM |
