camber on axel to much? - Fiberglass RV
Old 11-08-2016, 02:39 PM   #1
Unhappy camber on axel to much?
We just returned from a trip and while checking out the outside I noticed a lot of camber on both wheels. Jacked one side and both wheel came back to no camber. Took off one wheel and checked axel, all tight. We have radial trailer tires and wonder would they look like the trailer was super loaded,(which it wasn't)? The trailer now sits still and after jacking up then down there is no sign of camber. Lug nuts were tight. What is going on?
old guy is offline   Reply With Quote
Old 11-08-2016, 05:52 PM   #2
Dan Meyer's Avatar
I'm guessing you have a worn out axle.
Does the trailer seem to bounce on the tires instead of the springs? If so, replace the axle.
How long do your tires last, and do they have uneven wear? Even if they have uneven wear but you can get 5 years out of your tires, it might be best to just leave well enough alone.
--Dan Meyer
Old 11-08-2016, 10:05 PM   #3
The Minimalist's Avatar
Louisiana
You said you noticed a lot of 'camber'. Positive? Negative? How did you measure it? Camber is measured in degrees, and very few at that, normally, and not readily apparent just looking at the wheel.
A new axle will have positive camber, which is to say the wheels are closer to each other at the bottom than the top so that when the trailer is properly loaded, the flex in the axle will bring the axle back to a 0 degree camber, loading the tires properly across the tread and reducing tire wear. Are you showing unusual tire wear? A bent axle will cause negative camber making the tires wear more rapidly on the inner tread.
We need more information to be able to help you with your issue, if you in fact have a problem. Pictures might help.
Regards.
Clif
Fix for tire wear and positive camber Johnny M Towing, Hitching, Axles and Running Gear 33 07-30-2016 04:41 PM
1972 Hunter Compact Negative Camber Issue luckycharm Towing, Hitching, Axles and Running Gear 5 07-21-2014 07:25 PM
1985 U Haul with wheels w bad camber Susanne Problem Solving | Owners Helping Owners 2 05-27-2012 07:17 AM
How much is too much?? Pamela H Problem Solving | Owners Helping Owners 10 07-04-2008 09:47 AM
How much is too much?? Legacy Posts General Chat 12 06-05-2003 08:31 PM
