Camco Dual Flush vrs. Valterra Flush King on a Scamp 13 - Fiberglass RV
Old 08-06-2018, 10:45 AM   #1
Massachusetts
Ok, I am looking to purchase one of these two reverse flush systems, for my Scamp 13 which is in final assembly in MN. Both of these systems seem to be identical in every way (gate valves, water connections, etc.) except the Valterra has what appears to be a 23 deg offset angle. Whereas the Camco system is a straight thru fitting. Also, I am not sure if the Camco gate valve can swivel 360 deg's like the Valterra.
Since I do not know where the Scamp's waste fitting is located and how it comes off the Scamp, can anyone who has a Scamp 13 tell me which system would be less trouble some to connect up? The 23deg. Valterra or the straight thru Camco.
Thanks,
Jack & Jo-Ann
Lockman is offline   Reply With Quote
Old 08-07-2018, 09:53 AM   #2
Carl V's Avatar
Trailer: 1981 Trillium 5500
Quebec
I didn't know Scamp 13' came with a holding tank and RV sewer hose flush system.
I have a Camco Rhino Blaster, without the gate valve (you can get it with a gate valve too if you really want it). It is a similar product to those you mentioned.
The Rhino Blaster has a 45deg angle, and can swivel 360 deg. For me the gate valve is not required because you only have to swivel the hose end upward and that prevents the water from going down the hose and you can partially back fill the tank. Then swivel it back downward and the water flows out, with what was left in the tank. On the first back flush a lot of stuff still comes out, not much on the following ones.
I don't get crazy with back flushing the tank, I will do it a couple times and that's it, only when no one is waiting after me at the dump station. On the final flush of the season, before winterizing, I will rinse much more. In my case the blaster doesn't spray water directly in my tank because the outlet is not straight from the tank, there are 2 elbows, so it just back fills.
Once you're done, you close the trailer's gate valve and run the water to clean the trailer outlet, Rhino blaster, and hose. Again you can swivel up then down to fill and flush.
Of course you need water to make this work, and not all dump station have a hose you can connect to, many have a length of hose with a cutoff end. You can either remove this hose and plug in yours (I carry a short one just for this - never use your fresh water hose) or a "water thief" (I added manual clamps to my water thief because they don't hold much pressure before coming apart).
In all, I like the Rhino Blaster, works as advertised, I wouldn't by one that doesn't swivel or doesn't have an angle.
Scamp 16 #6 vrs. Casita 16 spirit deluxe Sue and Henry Problem Solving | Owners Helping Owners 14 01-24-2017 02:46 PM
Bug/rodent/water block for Valterra Electric Cord Doors wandererlee General Chat 5 09-09-2014 11:30 PM
Leaves vrs Lawn Tractor= FIRE! Pat B Ohio General Chat 3 11-13-2009 04:17 AM
Valterra Refrigerator exhaust fan Lisa H. Care and Feeding of Molded Fiberglass Trailers 15 07-14-2008 05:01 AM
Camping vrs RVing Paul Bostick General Chat 14 09-21-2007 04:12 PM
