Can fiberglass resin go bad? - Fiberglass RV
Old 03-07-2016, 06:34 PM   #1
Trailer: 1975 Boler
Quebec
This afternoon, in a warm garage, I mixed some fiberglass resin and some hardener together. It seems like I had the right proportions... I did my job, left and came back three hours later to find everything as liquidy as when I left. The resin was purchased a couple years ago. I didn't think it could go bad...can it? The tint was greenish instead of the regular caramel color.
I washed everything and started over with new resin. All seems normal this time.
Uncle Cereal is offline   Reply With Quote
Old 03-07-2016, 09:16 PM   #2
Dbybe's Avatar
Trailer: Happier Camper HC1 pulled with a 2011 Subaru Outback 4cyl CVT
I have used West epoxy that was a few years old without problems. The time I did have problems was when I was using the pre measured pumps that would pump out the Resin and Hardener at the correct proportion. I did not realize, but I was getting less hardener than the proper amount. (It seemed to be the right proportion). The epoxy never really cured, though it seemed to. Paint would not stick and I eventually had to torch it off the boat I was building.
Don
Sacramento
Don
Sacramento, California
Dbybe is offline   Reply With Quote
Old 03-07-2016, 11:01 PM   #3
madjack's Avatar
Trailer: 2015 Casita 17FD
Rapides Parish La.
...epoxy resin has an almost indefinite shelf life...fiberglass(polyester) resin has a definite shelf life...MEK can help it last longer...look on fiberglass boat forums for more info on this.....
madjack
madjack is offline   Reply With Quote
Old 03-08-2016, 08:13 AM   #4
deryk's Avatar
New Jersey
I agree about the pumps, they can clog and not give out equal portions so the mix would be off and not set right. I have used 10 year old resin and the only difference was it darkened a little more amber coloured as it aged. But worked fine.
deryk
Old 03-08-2016, 06:08 PM   #5
Thom Rowland's Avatar
Sometimes the hardening process needs to be triggered if the ambient temperature is not warm enough. You can do this with a heat lamp or heat gun. Even a blow dryer for hair can do this.
Thom Rowland is offline   Reply With Quote
Old 03-08-2016, 06:19 PM   #6
D White's Avatar
Trailer: Trails West Campster, CampStar, Uhaul, Fiberstream
The catalyst is definitely bad and probably the resin is bad also...sorry, but I would buy fresh...Fiberglass Dave
D White is offline   Reply With Quote
Old 03-08-2016, 07:29 PM   #7
Trailer: 13' Trillium
Were I work we make composite resins ( fiberglass ) is just one name.
As it gets old it will gell up , you can still use two year old resin but it may take longer to harden up. You should mix it 100 to 1 resin to hardener.
Last summer I was doing some fiberglassing and did not use enough hardener and it took over night to dry.
Hope this helps.
caderider1 is offline   Reply With Quote
Fiberglass Resin Recommendations? Seth and Desiree Modifications, Alterations and Updates 46 01-26-2015 07:01 PM
Fiberglass/resin prices? frank_a General Chat 2 07-29-2013 11:04 AM
Curing Fiberglass resin Per Walthinsen Problem Solving | Owners Helping Owners 9 02-21-2006 11:07 PM
Bad bad news Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
