Can I Cut These Off? - Fiberglass RV
Old 06-13-2019, 05:47 PM   #1
Trailer: ParkLiner
Virginia
I need to get under my trailer and these screws/bolts/whatever they are scare me. They come to a point and extend down about 2" lower than everything around them. If the trailer was to drop an inch when I am underneath it could be bad.
I think they just fasten the floor to the frame. I was going to take bolt cutters and snap them off about 1/4" from the frame. Any problem with doing that? Not all of them, just the ones in my way.
Huck is offline   Reply With Quote
Old 06-13-2019, 05:53 PM   #2
Steve Outlaw's Avatar
Trailer: Oliver Legacy Elite II
Mississippi
That will be fine. Better than a sharp screw in your eye...
Steve and Tali - Dogs: Reacher and Lucy and our beloved Storm and Maggie (waiting at the Rainbow Bridge)
2017 Silverado High Country 2500HD Diesel 4x4
Steve Outlaw is offline   Reply With Quote
Old 06-13-2019, 07:07 PM   #3
Raspy's Avatar
Trailer: Black Series HQ19 on order
Smith Valley, Nevada
No problem getting rid of the extra length. If I was going to do it, I'd use a 4 1/2" grinder with a cutoff wheel. Those are probably pretty hard.
If you don't have one, you can get them at Harbor Freight really cheap, and the wheels too.
Old 06-14-2019, 02:47 AM   #4
I have cut a lot of stainless and galvanized bolts and screws shorter using a Dremel motor and a fiber reinforced cut off disc. It is a lot easier to hold in your hands and get into tight spaces than a larger angle grinder.
Old 06-14-2019, 04:20 AM   #5
Raz
Raz's Avatar
Vermont
Hard to tell but those look like self drilling screws. My first trailer had them. They rusted away and had to be replaced. You might consider replacing them with standard bolts, galvanized or stainless.
Raz is online now   Reply With Quote
Old 06-14-2019, 06:20 AM   #6
If it’s anything like a Scamp, there are dozens. Replacing them all... nah. Just cut off the offender, leaving a little sticking out.
Old 06-14-2019, 06:55 AM   #7
Interesting... you asked "Can I," yet all the answers were to the question, "Should I."
I can see where future removal might be a little more difficult if you cut them off, but that's a minor issue (IMHO).
Old 06-14-2019, 09:29 AM   #8
Trailer: U-Haul 1986 -- got it 7/2013
Virginia
I'd rather cut them off with a Dremel or a right-angle grinder; that will minimize the damage to the threads, in case you ever need to undo them. The bolt-cutters will mangle the threads, making it difficult to unscrew them.
Pete Hein is offline   Reply With Quote
Old 06-14-2019, 11:31 AM   #9
minke's Avatar
Trailer: looking
A thought not based on experience: I'd put a nut on the bolt before cutting to be able to unscrew it after cutting using it as a cheap die to chase the threads.
I'd use a 4½" angle grinder too. Expect sparks all over. Make sure that nothing flammable is nearby. Wear gloves. WEAR A FACE MASK.
minke is online now   Reply With Quote
Old 06-14-2019, 11:59 AM   #10
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
I have used both methods many hundreds, even thousands of times. Because I mostly do it professionally, I use a grinder with a cut-off blade the vast majority of the time as you can do 10 with it in the same time as with a Dremel, especially when the material is really hard.
But, we all should just do what we are most comfortable with. If it is our own project time is not of the essence in many cases anyway.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 06-14-2019, 11:30 PM   #11
Trailer: In the market
Maryland
Huck, is that a wood floor I see on that Parkliner? I thought they were ALL fiberglass? I'm in the market for a used Parkliner because they are supposedly surround FG and the only thing wood are the cabinet doors. Would like to know, is that a wood floor? TIA.
Maria in MD is offline   Reply With Quote
Old 06-19-2019, 11:09 AM   #12
Doctor Harold's Avatar
Trailer: 1975 Scamp, 13-foot
Redding, California
Originally Posted by minke View Post
[FONT=DejaVu Sans, sans-serif]...
and EYE PROTECTION!!!!
You cannot have a proud and chivalrous spirit if your conduct is mean and paltry; for whatever a man's actions are, such must be his spirit. --Demosthenes
Doctor Harold is offline   Reply With Quote
Old 06-19-2019, 11:34 AM   #13
Trailer: Chalet Arrowhead
Future removal won't be a problem. They'll come out faster and easier. Usually the reason for long bolts in seemingly irrational places is to aid installation.
EricJ is offline   Reply With Quote
Old 06-19-2019, 11:35 AM   #14
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
HC1, EGG, and Lil Snoozy, are the only 3 that I know of that are built like that. There may be others.
Dave & Paula
Old 06-19-2019, 12:25 PM   #15
minke's Avatar
Trailer: looking
Eye protection is part of a face mask, or in OSHA speak, a face shield.
e.g. https://www.homedepot.com/p/3M-Clear...0025/202195394
Old 06-19-2019, 01:12 PM   #16
vintageracer's Avatar
Name: To Infinity & Beyond!
Trailer: 2 - Uhaul VT-16 Vacationer's & 1977 Argosy 6.0 Minuet
Wear a helmet when crawling under the trailer to avoid the "Long" bolts rather than cutting em off.
Another easy solution!
Mike
Remember "Drive Fast, Turn Heads, Break Hearts"!
vintageracer is offline   Reply With Quote
Google search results cut off nigeleccleston Forum Admin, News & Announcements 16 03-29-2018 09:34 AM
Tug throttle cut off when trailer brakes activated manually gordon2 Towing, Hitching, Axles and Running Gear 13 07-16-2015 03:18 PM
Low Voltage battery cut off???!!! dylanear Electrical | Charging, Systems, Solar and Generators 30 06-19-2012 09:47 PM
Is it ok to mount a battery isolation (cut off) switch inside the trai Curtis F. Problem Solving | Owners Helping Owners 8 07-05-2007 06:46 PM
