Can I secure flexible plastic moulding to ensolite seams? - Fiberglass RV
Old 11-12-2013, 07:49 PM   #1
Montana
I recently purchased a 1978 13' Scamp and the seams have lots of silicone smeared over the seams. I am trying to rub, scratch and pull the silicone off and would like to cover most of it with moulding if that is possible. Has anyone successfuly glued flexible plastic moulding to cover the seams before? If so, what type of glue was used? I've been reading through lots of forums and still don't know what to do with the ugly silicone smeared seams. Help!
rgillan is offline   Reply With Quote
Old 11-12-2013, 10:09 PM   #2
tractors1's Avatar
Trailer: Escape 21 - Felicity
Silicone caulk will absorb alcohols and then swell/soften, at which point it is much easier to scrape off with a single edge blade. Rubbing alcohol works well, but you need to soak a rag with the alcohol and let it sit a bit on the work area. Covering the wet rag with plastic (like Saran Wrap) will give the alcohol more time to work before it evaporates.
Charlie Y
Charlie Y
Old 11-13-2013, 07:03 AM   #3
ShawnKK's Avatar
Hot glue gun worked for me. Then I filled in the sides and painted the whole thing.
If you need to make a bend like in the pic just use a hair dryer to soften up the pvc trim.
ShawnKK is offline   Reply With Quote
Old 11-15-2013, 06:15 PM   #4
Montana
Thanks, I will be soaking with rubbing alcohol this weekend
Old 11-15-2013, 06:17 PM   #5
Montana
Thanks for the tip. I'm going to try to get rid of the worst of the silicone this weekend and then will try using the hot glue gun to put the moulding up. Its finally coming together!
New Int. Ensolite Seams Done! Whaler Modifications, Alterations and Updates 15 09-19-2017 04:17 PM
Ensolite seams and painting sherad Modifications, Alterations and Updates 7 04-30-2012 09:44 PM
Tape for Ensolite Seams Don A Problem Solving | Owners Helping Owners 7 11-17-2010 01:25 PM
Seams in Ensolite in a Scamp Evergreen General Chat 3 10-08-2010 08:36 AM
Trillium Plastic Seams Brenda Novakovski Classified Archives 2 02-19-2006 08:47 AM
