Can someone answer a bunk question with my Sc13? - Fiberglass RV
Old 04-16-2014, 06:30 PM   #1
Trailer: 1983 scamp 13
Could someone measure their bunk poles for me? When I bought my trailer a few weeks ago I had come across the poles for the bunks. I never tried to install them until today and something is not right. When I pull the back cushion up to install the poles the bed is not even by a long shot.
I am wondering if my poles were cut. My poles measure 23" overall and 20" at the cleat?, loop?). My poles need to raise 2-21/2" to become level. Also I have nothing to attach the bunk pole (cleat?, loop?) to the cushion. Is it as simple as a screw into the wood to hold it in place? Thanks.
firebike is offline   Reply With Quote
Old 04-16-2014, 07:13 PM   #2
Trailer: 2010 Scamp 16
I'll check mine when I get home if no one else has replied by then. The little loop on the side of the pole is wide enough to slip over a small screw on the bottom of the top bunk, then locks in when pulled toward the narrow part of the loop.
Should be two screws sticking part way out of the bottom bunk , pointed down. Directly above the cleats.
Old 04-16-2014, 07:28 PM   #3
Jon in AZ's Avatar
Looks like yours are short. Can't imagine why. Mine measure 25-5/8" and the cleat is about 3" down from the top.
Old 04-16-2014, 07:31 PM   #4
Great! Thank-you. I figured they were short and wanted to be sure before I order more from Scamp. Also I do not have screws in the bottom of the cushion, but I can fix that.
Old 04-17-2014, 05:14 AM   #5
Humm, any way you can get in touch with the sellar and ask WHY they pole were cut? There had to be a reason.
Can someone ID this one ? ted saxton General Chat 15 03-05-2008 09:10 AM
Can someone help ID a trailer? Kenny&Jackie General Chat 4 08-29-2006 09:27 AM
A Sc13' Deluxe Problem RonMayo Problem Solving | Owners Helping Owners 5 08-02-2006 12:46 PM
Answer a Question then Ask a Question CarolnJim General Chat 77 06-03-2006 11:39 AM
