Can't Find the VIN Number on the Trailer to Register? - Fiberglass RV
Old 02-27-2009, 01:47 PM   #1
Cyndivg11's Avatar
Trailer: 1984 FiberStream
I just bought a 1972 trillium trailer with plans to restore it.
I have the title. The previous owner does not know where the vin number is. I bought it in NJ, I live in PA. Driving back I got a warning from the PA state police- I have to register it in 10 days. The notary/registration people need me to rub off the vin number on the trailer with pencil. I can't find it. Can anyone tell me where to look?
Thanks,
Cyndi
Cyndivg11 is offline   Reply With Quote
Old 02-27-2009, 03:49 PM   #2
Raya's Avatar
I know it was (at least on a 1976 Trillium 1300) on a piece of paper on the backside of the closet door. I didn't ever see it anywhere on the frame, although that does not mean it wasn't there somewhere. I had no reason to look since the paper inside the door was clearly original, and no-one asked to see anything else.
I haven't found a number on the Boler frame either, by the by. It's on a "metal" (actually more like a thick foil) plate on the side of the fiberglass shell, and then also on a factory paper label inside the (in this case kitchen) cupboard doors.
I think some people have found numbers on the frame though. Not sure if they're on all the trailers, under the paint, or if only some have them.
Raya
Old 02-27-2009, 05:47 PM   #3
Trailer: 1978 Trillium
Thanks,
Cyndi
Hi Cyndi, I have a 78 trillium 4500, I ground down the entire frame and came across the vin. # stamped in to the frame on the tongue of the trailer . On the top side of the frame rail right side looking at the window. could not see it before I took all the paint off. in front of the propane tank holder. hope that helps, but they may have put it on either side . But I'm sure you will find it along the top rail . Ian.
Ian Harrad is offline   Reply With Quote
Old 02-27-2009, 07:10 PM   #4
Cyndivg11's Avatar
Raya
Thanks for the reply- actually Trillium called me back in about 3 minutes after I left a message...they informed me they didn't put them on in 1978- but like you said, there on a piece of paper on the exterior above the left exterior light and inside the closet. I have to fill out a 'special' form, take the trailer to a 'special' inspection station...I think what I'll do is take the form to the State police barracks and show them it's a longer process...maybe they'll give me an extension before they issue me afine. Thanks!
Old 02-27-2009, 07:30 PM   #5
Hi Cyndi, I know there is one stamped on my frame rail and it is a 78. Its not a plate but stamped into the metal rail as well as the paper inside the closet. Hope all works out for you. You could always stamp your own onto the frame. Its your trailer. Ian.
Old 02-28-2009, 12:58 AM   #6
Roy in TO's Avatar
Cyndi,
Does one of the pieces of paper have the serial #?
If so a picture of that should do the same thing as a pencil trace.
It seems odd that you need to do that all that if you have a title.
Does the title not have the VIN on it?
Back in 78 it probably was not the 13 or so digit numbers they use now.
Old 02-28-2009, 01:03 PM   #7
Trailer: Fiber Stream
Talking
I haven't found a number on the Boler frame either, by the by. It's on a "metal" ([b]actually more like a thick foil) plate on the side of the fiberglass shell
This is also how Fiber Stream did it. Mine is located beside the front (amber) driver's side running light.
The thick foil was run through a Typewriter to add the numbers before it was applied to the trailer's shell.
17-digit VIN's (Vehicle Identification Numbers) were invented for Travel Trailers in 1980 or 1982.
Previous to that, they were called Serial Numbers and the process was much simpler for the manufacturers.
Since mine did not have a tongue-stamped number, I added this myself.
Old 03-01-2009, 01:02 AM   #8
Raya's Avatar
That's a good idea The foil one on my Boler is almost illegible after all these years, so that would not be a bad idea for me either. How did you go about it? Did you stamp right into the frame? Or on a plate that you then attached? What tools did you use?
Raya
Old 03-01-2009, 05:50 AM   #9
Metal stamping tool, cheap solution for putting VIN on the frame: 36 Piece 1/8" Steel Letter/Number Stamping Set
Old 03-01-2009, 11:01 AM   #10
Talking
Yes, My work owns that set, and I used it to stamp the number directly onto the tongue frame.
Use a hammer with some heft to it, a carpenter's hammer is too wimpy.
(Don't ask me how I know this.)
Old 03-01-2009, 04:53 PM   #11
Trailer: 1973 Trillium
Send a message via AIM to georgia g
We have a 73 Trillium and the vin # is on the tongue. Not into the metal but raised and quite large. Even with all the old paint on ours I can see it. Good luck. georgia g
georgia g is offline   Reply With Quote
Old 03-21-2009, 03:50 PM   #12
Georgana D's Avatar
Trailer: 1996 16 ft Scamp and 1990 16 ft Scamp
Pa is a goofy state in regard to VIN and registration. One Scamp from Mass and one from NJ .
We had to take the trailers to the tag place and they had to come out and visually match the numbers. They were so shallow that we ended up applying for new plates to pop rivet onto the frames. The local police sent out an officer to visually check the numbers again.
It ended up costing a few extra bucks but in the end we have clear VIN #'s.
You may want to consider doing it in case the paper gets damaged.
Good luck,
G
Georgana D is offline   Reply With Quote
license, registration, title, vin
Where to find?? - for Lil Bigfoot Trailer Mike Whitney General Chat 14 07-27-2009 08:33 PM
Trailer/RV parts - Where find? francene Care and Feeding of Molded Fiberglass Trailers 2 05-16-2009 12:11 PM
How to license/register trailer in Indiana Anne Badgley Problem Solving | Owners Helping Owners 4 04-01-2009 02:27 PM
Where to Find Fun Accessories for your Trailer D & K Watling General Chat 2 07-24-2007 06:33 PM
HELP to find the right trailer davidhopkins Wanted: Molded Fiberglass Travel Trailers 3 04-21-2006 06:16 PM
