Can't get at my frost plug - Fiberglass RV
Old 10-05-2009, 06:38 PM   #1
Trailer: 1980 Bigfoot 17 ft
I am a new owner of a 1980 17' Bigfoot travel trailer and I am also a first time winterizer of the same. I have got everything done to winterize, according to the manual provided however-the hot water tank, I have drained it using the valve but I cannot quite get a tool on the frost plug to remove it completely. Do I really need to remove it. As stated I have drained the tank and I live in Vancouver Canada where the coldest it gets is about tthe same as Seattle, Washinton. If I do need to remove it completely any ideas on how to get a handle on it, it is sure tucked in a very challenging spot-many thanks, R. Lamb
ROIDON L is offline   Reply With Quote
Old 10-05-2009, 06:53 PM   #2
IllAnnoy
I'm not sure what you have done already, but if you are talking about the plastic plug on the lower left corner of the water heater as viewed from outside the camper with the door open, then all you really need is a 3/8 drive (7/8ths I think)socket with an extension and a rachet. this allows easy access around the pipe that is in the way on mine.
Old 10-06-2009, 11:45 AM   #3
Trailer: 17.5 ft and 25 ft FB Bigfoot
I have two Bigfoots and all I do is turn the plastic plug back in until it is just finger tight, after I've drained it for winter. It is a hassle to take it out but I do it after each camping trip and I use a small cresent wrentch.
Tamid is offline   Reply With Quote
Old 10-06-2009, 01:20 PM   #4
Many thanks I willl give it a try-my tool box is lacking and I guess this is a clear indication that it too needs an upgrade
Marine plug Jim Hovind Plumbing | Systems and Fixtures 14 02-18-2013 03:30 PM
Can you plug into 120 while the 12v batteries are out? Cam A Care and Feeding of Molded Fiberglass Trailers 8 06-30-2010 09:25 PM
Frost damage? Wilder Care and Feeding of Molded Fiberglass Trailers 4 12-06-2009 09:48 AM
plug adaptor Mike Whitney Towing, Hitching, Axles and Running Gear 11 07-05-2009 10:27 AM
Bargman Plug Norm Roy Problem Solving | Owners Helping Owners 4 04-12-2006 08:33 PM
