Can the interior spring in a roll out awning be fixed or replaced? - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Problem Solving | Owners Helping Owners
Click Here to Login
Old 07-02-2016, 07:28 AM   #1
Trailer: '79 13' trillium
As the title says, I'm looking for some help with my awning.
Can the internal spring in a roll out awning be fixed or replaced?
When we take the awning out of the metal case, it rolls out easy and all the poles are there. It's just such a hassle to get it back in because the spring doesn't 'pull' it back toward the trailer.
I'm in southern Ontario. Help?
Ksimdjembe is offline   Reply With Quote
Old 07-02-2016, 09:56 AM   #2
Yes, it probably can be replaced or re tensioned but be very careful if you try to do it yourself. I just replaced the awning material on my Bigfoot and did it myself. There are several U tube videos that show you how to di it. I had an A & E brand but there are others. Find the make and model number and do a google search. You should be able to find everything you need. Parts and instructions are listed, but again. be careful. Those springs are under severe tension and if not released properly can cause injury.
awning
Where in BC can I have propane line fixed? branch Modifications, Alterations and Updates 7 09-14-2011 09:13 AM
What kind of window do we have here and can it be fixed? Heidi H Care and Feeding of Molded Fiberglass Trailers 8 08-19-2010 11:30 PM
Boler was rear ended - can it be fixed? Brenda M Problem Solving | Owners Helping Owners 19 07-19-2009 12:40 PM
For those that have replaced the interior covering... Stacy Crotser Problem Solving | Owners Helping Owners 30 05-16-2009 07:54 PM
My '82 Burro needs floor fixed or replaced, I need advise MikeCM Modifications, Alterations and Updates 5 03-11-2009 04:28 PM
