can use advice on vent - Fiberglass RV
Old 03-22-2016, 05:45 PM   #1
Have 16 Casita, older model it does not have a bathroom vent. I would like to vent the room not just the plumbing. Have thought about the vents that are for the pipes as a room vent, even the one with the solar fan. I notice the newer models have a vent, or is that another pipe vent?
Thanks for any helpful advice.
old guy is offline   Reply With Quote
Old 03-22-2016, 06:18 PM   #2
I installed solar powered vents on the toilet vent and another one on the refrigerator vent (To help it move the hot air out of the back of the Fridge)
Ultra Fab Mini Solar Plumbing Vent - $21.97
Old 03-22-2016, 07:37 PM   #3
This is what Scamp is using now for ventilating the bathrooms (not the plumbing).
I have one.. its OK but you have to cut a pretty big hole in your roof (6.25 inches) Mine had a gap in the sealant when it was put in, so it leaked at first.
Old 03-22-2016, 09:18 PM   #4
tractors1's Avatar
Trailer: Escape 21 - Felicity
Lots of rental places have really big hole saws you can rent if needed; just need a half inch drill to use them (of course you could rent that too.) Otherwise, a Roto-Zip tool works well; just go slow.
Charlie Y
Old 03-22-2016, 11:43 PM   #5
A Hole Saw of the correct size will give you the perfect round hole.
Old 03-23-2016, 06:41 PM   #6
I can cut a hole most any size, I was looking at the wall and I looks like a double wall.
Do the vents have some kind of finishwork for the inside? By the way thanks for the replys
Old 03-23-2016, 06:45 PM   #7
tractors1's Avatar
Yup. Pix here:
Ventline Vanair Trailer Roof Vent w/ 12V Fan - 6-1/4" Diameter - Smoke Ventline Enclosed Trailer Parts VP-543SP
Charlie Y
Old 03-23-2016, 07:25 PM   #8
Charlie , that sounds good except I don't have power near but I guess that may not be to hard to fix. Do you know if that vent has minimum roof thickness?
Old 03-23-2016, 08:10 PM   #9
tractors1's Avatar
Nope, but it looks like the standard Casita vent. If you call Casita and ask for Victor, he'd sell you one for probably not much more. You can snag the power/ground wires from the ceiling above the bathroom door, they're tucked in behind the carpet.
Charlie Y
Can you use some money? Roger C H General Chat 8 11-05-2013 06:16 PM
What Laminate Flooring did you use? Would you use the same brand again? iplumb Modifications, Alterations and Updates 24 01-14-2012 09:30 AM
Need advice on flooring and vent Jola & Liz S Modifications, Alterations and Updates 15 08-04-2011 09:42 PM
What can I use to trim the edge of stove cutout??? Vickie B. Problem Solving | Owners Helping Owners 8 05-27-2011 01:07 PM
Can I use 3M 90 adhesive at temps less than 65? Vickie B. Problem Solving | Owners Helping Owners 2 05-13-2011 08:01 PM
