can you help me identify make and year - Page 2 - Fiberglass RV
Old 02-14-2016, 09:52 AM   #15
Vic&Kathy's Avatar
Trailer: Trail Mite
Originally Posted by TeresaG2 View Post
The only ones I see with the wide raised fiberglass band (see my picture) on the upper half are surfside and trillium and maybe trailmite(?)
It's not a Trailmite, those have a unique "eyebrow" over the front window and the center band extends into a tail-light shelf.
Vic&Kathy is offline   Reply With Quote
Old 02-15-2016, 06:52 AM   #16
Originally Posted by Donna D. View Post
The wheel wells are filled like a Casita, but Casita didn't use that style door hinges on early 13 footers.
Noticed that as well, and was wondering about the rest of the bottom- full fiberglass or wood?
Old 02-15-2016, 07:46 AM   #17
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 1995 Coachmen 19' B-van
Iowa
If you read the history of Boler America, you'll find that they contracted with (I believe) seven companies across the US to manufacture the trailers in the year or so before they closed. Scamp emerged from that debacle, and Casita yet from Scamp. There were a number of trailers built as Boler Americans that ended up being "home-builts" because the company went under and sold shells and partially completed trailers.
During that time there were literally also dozens of startups that made one or two trailers and then folded. Making a trailer is easier than marketing them. Each of them were loosely based on the Boler design, but had a minor change or two in the design.
This thread from about ten years ago (can it really be that long ago?) may have some hints and tips that may help you identify yours, but I'm guessing that your VIN is a DMV-issued home-built VIN from one state or another.
Egg History- Boler descendants
Old 02-16-2016, 09:30 PM   #18
Trailer: Scamp?
Lots of info, thank you to all. I am beginning to think like so many, that we we have a mutt, which is just fine if we can get it registered so we can use it when we want.
If I am reading the TX registration info correctly, we cant do homebuilt if it is a travel trailer. We can travel on temp tags but for limited couple of times per year.
I think if we can confirm frame make and year we may be able to register ---maker and year needed, though I know from there up may differ. I feel the bottom half and frame are a match but think that along with the taillights that it has a new top half and door.
I am including some more pics if anyone cares to take another crack at it. I am showing several different identifying (I hope) areas, but am mostly interested with frame and possible year.
We started sanding Sunday and found it was red, and maybe before that white on the bottom and white on top before the fancy painting. One responder asked about the hinges, they are the triangular type now but do have extra filled in holes a couple of inches away from them also, again, a redo I think. We have sanded deeper in places where there are normally logos and I have found no decals or ghosting from decals....darn!
Thanks again, great working with so many knowledgeable people!
TeresaG2 is offline   Reply With Quote
Old 02-16-2016, 10:05 PM   #19
Dudley's Avatar
Trailer: 1998 Casita 17 SD
I know its a long shot but is there any stickers in the closet, on our Ventura there was a plastic info decal on the cupboard door with the manufacturers name and serial number as well as the installed equipment. It may just be a canadian requirement.
I also read somewhere here that one of the northeast states issues titles by mail. Then take that one in to your state and transfer title. I cannot find the post about it.
Old 02-17-2016, 06:45 AM   #20
Maine. Some PA residents have gone this route with home made teardrop campers and restored vintage campers that had no paperwork. Here in NY we can do a "Home Made" registration with a weight certificate and DMV will issue a VIN number
Old 02-17-2016, 07:13 AM   #21
I keep coming back to the full fiberglass bottom together with the Boler-derived shape. Besides Casita, what other Boler clones have a full fiberglass underside?
Old 02-17-2016, 08:48 AM   #22
David Tilston's Avatar
I have seen that trolley roof before. It is unique in that it extends all the way to the back. I am sure there was another one like this, also looking for an identification. That one had clearance lights on the extended trolley roof though.
Old 02-17-2016, 08:58 AM   #23
I remember that one David... I searched but couldn't find it. Unik?? If so this one is aptly named, as it's unique!
Old 02-17-2016, 09:16 AM   #24
No, not a Unik either... unless a waaay different year. This is a 1975
Old 02-17-2016, 09:35 AM   #25
Trailer: 2014 Escape 21
Virginia
Even if you find the Mfg. you still don't have a title. You can treat it as a homebuilt kit travel trailer. I would have some "what if" conversations with the officials involved before starting the process. The way I read it you can have a shopbuilt or homebuilt travel trailer in TX. Just so the trailer is built by you or to your specifications. Once you start modifying the shell it is being built to your specifications. You can also research how home built teardrop trailers are registered in TX.
TxDMV.GOV - Trailers
Eddie
Even if you call it a Scamp or whatever Law Enforcement will still have to verify the Vin to ensure it hasn't been reported stolen before getting tags.
Old 02-17-2016, 10:00 AM   #26
You're right, Donna. That's not the one I am remembering. It had the extended trolley roof, and, as I recall, some kind of oversized window retrofitted into the back. You called it that time, as I recall (as usual).
Old 02-17-2016, 10:14 AM   #27
I'm STILL looking! Dang this is bugging me.
Old 02-17-2016, 10:19 AM   #28
Tom Trostel's Avatar
Trailer: 1980 Bigfoot 17 ft
You might phone or email this company in Maine and explain your problem. If it's older than 15 years, Maine does not issue a title but you will get a registration and license plates. They no longer issue home built titles so you may need to name the trailer something.
Trailer Registration - Haskell Registration
Can you identify this lock? - Boler 13' Butterflies Problem Solving | Owners Helping Owners 11 05-27-2015 02:52 PM
Mystery parts, can you identify these for me? Ryan P R Problem Solving | Owners Helping Owners 10 03-30-2013 10:34 AM
Hi I am Cat Lady and if you are in NY and going to Arizona you can make 1000 dollars Cat Lady Hi, I am.... 6 11-17-2012 07:25 PM
Can you help Identify Flygal General Chat 7 01-15-2008 09:21 PM
How can you tell what year a Trailer make is? ericmarlo Money Matters 11 09-20-2007 09:12 PM
