Canadian source for water tank for 17 ft. Boler - Fiberglass RV
Old 05-03-2010, 09:14 PM   #1
kevin61's Avatar
Trailer: 13 ft Boler and 17 ft Boler
I'm looking for a new water tank for the 17 ft. Boler and was pointed towards this outfit in Lacombe, Alberta.
http://www.dmplastics.ca/company.htm
I checked their list of products and came across tank # RFW 1513 that is identical in profile to the one I removed. The pdf shows their tank which is slightly larger at 88 litres instead of 77 litres.
The photo is of the existing tank.
RFW1513__water_tank_for_17_ft._Boler.pdf
DM Plastics has the original molds for this tank. They may also have the mold for the graywater tank as well
Tank Pricing
Our tank model #RFW1513 with female pipe thread bushings, hose barb adapters, filter screen, and drain cock; $148.69 our dock, plus GST.
We have one tank stock and will build more during this week.
Thanks.
Mark Nicholas
D&M Plastics Inc.
1-800-558-7476
info[at]dmplastics.ca
kevin61 is offline   Reply With Quote
Old 05-04-2010, 12:04 PM   #2
Trailer: 1979 17 ft Boler
I ordered the same unit from DM and just received it last Friday. It's identical to the one I pulled out so either the old one is 88L or the new one is 77L. Either way it fits perfectly.
timmckee is offline   Reply With Quote
Old 05-04-2010, 12:32 PM   #3
Kevin,
I watched your tank removal video on You Tube. It looks like a repair was done on the low end around the drain. Mine had similar damage/repair done to it. I also noticed when I removed it even though the drain valve was open there was still 1-2 litres of water inside. I can't see how that little of water freezing could damage the tank but after seeing yours I'm starting to wonder. Of course another explanation is both tanks were left filled and allowed to freeze. I'm thinking of adding a 1/2" female fitting on the underside with a plug to fully drain it in the fall.
What do you think?
Tim
Old 05-04-2010, 12:47 PM   #4
Mike Bromley's Avatar
Trailer: 1973 Boler 1300 (Glass-Fab
When draining my tank I jack my trailer up on the side opposite the drain to ensure that as much water as possible gets out.
I also jack the trailer when filling the tank to make sure all the air gets out.
Mike Bromley is offline   Reply With Quote
Old 05-05-2010, 07:12 AM   #5
kevin61's Avatar
What do you think?
Tim
Tim,
I'd probably go with Mike's idea of jacking the trailer. However using a plug as you suggest, that sits flush as opposed to a drain cock which sticks out and could be easily snapped off by road debris would probably do the trick
Old 05-18-2012, 01:01 AM   #6
Rocker's Avatar
Trailer: 1979 17ft Boler
Saskatchewan
black water tank 17 foot 1979 Boler
Anyone know if they have the black water tank too? If so, do you know the part number? I figure for that price I would swipe both out. thanks for the info!
Glenn
Previously a 1975 Ventura Owner, now a 1979 17 foot Boler owner!
Rocker is offline   Reply With Quote
boler
Leaking Grey Water Tank on Boler KevinDR Plumbing | Systems and Fixtures 10 09-10-2021 07:53 PM
Water tank for boler 1700? Patton M. Problem Solving | Owners Helping Owners 3 09-08-2009 03:15 PM
New to Me Boler - Help Awning & Water Tank Michelle A Problem Solving | Owners Helping Owners 17 05-12-2009 07:26 AM
Boler Water Tank Installation Roy in TO Care and Feeding of Molded Fiberglass Trailers 10 04-26-2008 09:30 PM
17' Boler Black Water Tank Dwight Burditt Problem Solving | Owners Helping Owners 6 04-18-2008 09:16 PM
