Canopy attach advice please - Page 3 - Fiberglass RV
Old 05-17-2012, 05:20 AM   #29
Tim Wood's Avatar
Trailer: 2006 17' SD Casita
NY
I do remember someone using the tape for a solar panel too, maybe Norm? You could always use the suction cups that the bus depot uses on their awnings. Here is a link for those who missed it.http://busdepot.com/details/awning.jsp
Old 05-17-2012, 08:33 AM   #30
Trailer: 77 Scamp 13
Originally Posted by Sue and Henry View Post
I can say " wish you were here" and really, really mean it! I'm going to order the vhb tape from amazon tonight. If it'll hold a solar panel it should hold an awning rail.
I'm sure when you are done you will sit back under your very nice awning and enjoy both the functionality and the satisfaction from having taken on a challenge successfully.
Old 05-17-2012, 10:33 AM   #31
Harlequin's Avatar
Trailer: 1991 Scamp 13'
Virginia
as another note about the strength of the tape, GoPro uses 3M VHB on their sticky back camera mounts. While the camera isn't really what you would consider heavy, they hold the thing pretty much rock solid in high speeds (personally used at 70mph on the outside of a car, seen video shot doing things like skydiving, where you can be going upwards of 120mph during freefall).
Harlequin is offline   Reply With Quote
Old 05-17-2012, 02:37 PM   #32
Sue and Henry's Avatar
Name: Sue and Greg
Trailer: 1982 Burro 13 foot and a 2015 Casita Spitit Deluxe 17 ft.
Great information Tabitha. I've ordered the stuff, now I will expect fiberglass fans across the nation to have their fingers crossed in a show of unity!
Sue and Henry is offline   Reply With Quote
Old 05-27-2012, 11:19 AM   #33
Name: Sue and Greg
My Developing Solution
Last night my hubby and I attached the 3M tape to coat hooks at put them on the Burro. 3M said to let it sit for 72 hours, but I couldn't stand waiting - so this morning I put on the pv pipe frame. We used 1/2" pipe and put in wooden doweling to firm it up then put rubber caps on the two legs. Keep in mind this is as yet unproven. Who knows what a good gust of wind will do. Next to the sewing machine to sew a bunch of shoe laces on for ties.
Okay. It is right side up in my original ... I have no idea why this is upside down, but I cannot seem to fix it. Sorry. Stand on your head?
Old 05-27-2012, 11:32 AM   #34
Pam Garlow's Avatar
Trailer: U-Haul 1985
I have a Uhaul (same hull construction as the Burro) and agonized for a year as to how to connect my awning without drilling. In the long run, I just didn't trust using just the tape alone. Plus the 3m structural vhb tape (the really strong stuff that they stick windows onto skyscrapers with) was very expensive. (There appears to be various levels of 'sticky'?) Anyway, I felt better using additional mechanical fasterners so I used an exterior grade adhesive tape from my local big box store, and then pop-riveted through it. The first hole was the hardest (mentally) to drill through the hull, but after that, it was simple. I figure that this is an easy item to monitor and keep caulked and I don't worry that my awning will get pulled off the side of the trailer in a sudden high wind. I'm just too much of a worry wart so I played it very safe. I'm really interested in this new awningattachment works out, thinkgin it might be a good way to attach a secondary 'shade' awning for the back of my trailer....
Old 05-27-2012, 12:33 PM   #35
Name: Sue and Greg
Hi Pam, our awning isn't a nifty new one - it's an old fashion thing. I needed something inexpensive (it really didn't work out that way with fabric and parts but I had a ton of fun doing it anyhow) and fairly easy for me to set up alone. When I am traveling all I have is three hooks running on the fiberglass roof. If they fail, it won't be when I'm traveling. I did use the tape 3m suggested. It's the VHB heavy duty mounting tape. The smallest I could find was a 15 yard roll on EBay for $35 or so.
If you are on the west coast somewhere - that's where I'll be traveling this summer - I can share if you are interested after checking it out.
Old 05-27-2012, 03:33 PM   #36
Pam Garlow's Avatar
Sue, I'm in Michigan, a bit too far away to personally see your trailer. But your closeup photo cleared up any confusion about how the attachement works. Very ingenious ! Installing hooks that way might be an option for many things from attaching a shade awning on the roof, to a smaller awning above my back window. Thanks for the additional photo!
Old 07-31-2012, 11:12 AM   #37
Robin G's Avatar
Trailer: 2007 Casita
[QUOTE=Sue and Henry;310629] I did use the tape 3m suggested. It's the VHB heavy duty mounting tape. The smallest I could find was a 15 yard roll on EBay for $35 or so.
QUOTE]
Sue, so how is the tape holding up? Been chomping at the bit to get a awning project going, but I am still struggleing to figure away to attach awning rail..... So I am hopeing your 3m is holding up well! Because that will make my project so easy peasy! Feedback please............
Old 07-31-2012, 12:14 PM   #38
Roy in TO's Avatar
I have experience with the 4991 series, it's the gray stuff.
Byron, was that a typo? the link you provided refers to the 4941 family.
Originally Posted by melissab View Post
How do you make sure you get the 3M VHB tape on straight?
Getting it straight is scary, but I'm thinking erasable marker.
I would use the awning rail to mark the trailer using a pencil. To get it straight use the awning rail to measure equal distances from the raised portion of the roof towards the front and rear while marking where you want the beginning and end to be positioned. Then using 2 people, I would apply the tape to the awning rail and then seat the rail to the marks.
For those who want to know: I called the help line at 3m for the application of of their VHB tape. For my application, she said no. 5952 would be what I want.
That is interesting, when I read the info on the link Byron provided earlier; the 5952 mentions metal and various plastics, while the 4941 says it is for outdoor and harsh enviormental applications. To me the roof of our trailers more closely matches the latter.
Originally Posted by Nancy View Post
I would think if you had leftover yards you might be able to work something out with other people ...
I'd be aminicable to something like that. Pay for what's left plus shipping, use what you need and have the next person do the same. Then again there is enough stuff around the trailer, home and office that I could find uses for it.
Old 07-31-2012, 11:24 PM   #39
Trailer: 2005 13 ft Scamp / 2004 Honda Odyssey
Robin,
Sue shared a piece of her tape for me to try. I did as the instructions stated, but must have done something wrong. I tried a small piece to use inside for a metal hook. Put it on the metal hanger, wanted til the next day and applied it to the interior fiberglass. After a few days gave it a try. Hung my slacks on it at night. One night it fell down. Honestly I have the most rotten luck. That hook is going to get a screw to hold it in place. Wanted to use the tape as there isn't lots of room for drilling.
I solved my awning problem. We bought a $30 sun shade on sale. Two of the four poles are not used. The shade rests on the fiberglass and is tied down to the bumpers. Tested it out on our last trip and we are happy. Only problem is that it does not reflect the sun and is warm below. Posted a picture on the Manitoba gathering thread (page 6). The Canadians came up with the plan, I just copied. Found the same shade (Northwest) on the Sears web site. We only have a 13 foot. Not sure if this way would work with larger trailer. The 9 foot square curved around our 13.
Nancy
Nancy is offline   Reply With Quote
Old 07-31-2012, 11:48 PM   #40
Robin G's Avatar
Thank You Nancy!
Old 08-10-2012, 12:31 AM   #41
Name: Sue and Greg
[QUOTE=Robin G;324625]
QUOTE]
Old 08-10-2012, 12:35 AM   #42
Name: Sue and Greg
So far it is holding up well, but we've travelled a lot and have only attached the awning twice for two and three night stays. We have had rain weighing down the awning and light wind. We have not had a hard wind to challenge it yet.
Attach wood to gelcoat??? artspe Modifications, Alterations and Updates 20 04-06-2012 03:20 PM
Attach small windows with bolts? Amy M Problem Solving | Owners Helping Owners 13 04-04-2012 05:54 AM
Leak Repair & Best Way to Attach Modifications sugermc Problem Solving | Owners Helping Owners 15 11-16-2009 10:57 PM
HOW DO I RE-ATTACH BELLY BAND Mary Lynn K. Problem Solving | Owners Helping Owners 19 05-30-2006 05:38 PM
How did you attach your sway bar? Chris Z Problem Solving | Owners Helping Owners 9 04-11-2006 06:59 PM
» Trailer Showcase
Mildred
Jim er
Casita
Chris Z
