Capping propane lines - Fiberglass RV
Old 07-10-2007, 09:52 PM   #1
Trailer: 73 Boler 13 ft
We are off on a trip tomorrow, with only the stove working. So the propane lines for the furnace and the fridge are unhooked and just out in space. What do we do with them when they are not hooked up to anything. They are slightly flared at the end. Thanks!
Peggy is offline   Reply With Quote
Old 07-10-2007, 10:00 PM   #2
Brian B-P's Avatar
If they each have a shutoff valve, I would cover the end with anything just to keep dust, water, etc. out, and tape over the valve so it is not accidentally opened. Without a shutoff valve... well, I'd install a shutoff valve, but there probably are shutoff valves already, if the stove has been in use...
Old 07-10-2007, 10:27 PM   #3
Greg A's Avatar
Trailer: 2015 Escape 19
Peggy,
I don't think most folks here, in the 13's at least, have ever even used their stoves. Most cook outside on portable propane stoves or grills. The stove in a 13 will heat you out in under one minute which could be nice in Winter. We've never turned ours on yet. Personally, I'd take the propane bottle off the tongue and leave it until you finish getting all the systems hooked up and tested.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 07-10-2007, 10:41 PM   #4
Nope, no shut off valves, just a copper pipe with a flared end. Are the shut off valves availabl at a Canadian tire, or more specialty stores, I guess you have to cut the pipe. Will they be compression fittings? We'll add them in, anyway.
Old 07-10-2007, 10:53 PM   #5
Inserting shut off valves, if there are none would probably be a good idea.
As for cooking inside the trailer, over 90% of our cooking is done inside. One of the reasons for getting the trailer was to reduce the amount of set up and tear down. Since we have perfectly good cook top inside and all the cookware is inside why lug all the stuff outside so you lug it all back in?
Byron Kinnaman is online now   Reply With Quote
Old 07-11-2007, 04:51 AM   #6
Trailer: 1979 Boler 1300 / 1991 Casita Freedom Deluxe
Maine
With the slightly flared end still on the copper tubing it still must have the flared nut on the tube itself.
At any hardware store you can by a cap to fit this flared nut to cap off the gas line. AND DO A BUBBLE TEST WITH GAS ON.
A so called RV repair man who couldn't find the problem with my furnace did this and all it needed was an new Thermostate so I hooked it up myself.
Gerry the canoebuilder
Old 07-11-2007, 06:57 AM   #7
Joe Z's Avatar
New River AZ
Peggy....
I like to do the simple and least expensive things first so I'm what some would call a "backyard mechanic" you say your stove is working....... while the fridge and furnace are unhooked?...... sounds like they (the furnace and fridge)are shut-off somewhere already! if your not sure just do a small test by temporarily for this test putting a childs balloon over those open fittings and see if they blow up the balloon and if they do then just get the appropriate cap like someone else mentioned in an earlier post and install with a little teflon tape just to be sure and do the bubble test....... if they don't leak then just cover them with something to keep the dirt out.
joe
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Old 07-12-2007, 04:12 AM   #8
Maine
Peggy....
I am also a "Backyard mechanic" but also hold a licence for Mechanical Engeniering, (Fancy name for a Plumber and done a bit of gas pipeing also.
Even if I knew that these lines had a shut off valve stareing me in the eye if I wasn't going to hook them up to the proper gas valves I would cap with a brass cap cost maybe $1.
Better to be safe then blown up!
I know that in my Boler the valve, going to the fridge, is a spring type valve and now these are illeagal to even install on gas lines, in homes, let alone a trailer, vibrated going down a road.
Old 07-12-2007, 05:54 AM   #9
Joe Z's Avatar
New River AZ
Gerry...
Have to agree with you ...... put a cap on it to be sure. I had a momentary brain freeze LOL
Joe
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
propane
Gas Lines Vicki A. Problem Solving | Owners Helping Owners 21 09-10-2010 01:04 PM
New propane lines in a Boler 13 Raya Care and Feeding of Molded Fiberglass Trailers 25 10-14-2009 02:30 PM
Where to Buy? New propane lines, fittings, etc? Kurt in BC Problem Solving | Owners Helping Owners 9 06-12-2008 05:27 PM
Propane lines Jim Hovind Problem Solving | Owners Helping Owners 3 01-09-2006 08:30 AM
Propane lines General Chat 0 01-01-1970 12:00 AM
» Trailer Showcase
TED
Spanke
Junior
JenPB
