Carbon monoxide detectors - Fiberglass RV
Old 02-15-2012, 09:13 PM   #1
Trailer: Casita 17' SD
Montana
We will be picking up our new egg in May and I want to add a CO detector. I realize from the forums that many of you do not have CO detectors or you disconnect them due to false alarms. Nonetheless, I am a believer in them and plan to install one. (Too many real-life tragedies every year to ignore.)
My question then, for those who use CO detectors, is whether I should buy a "plug in" type (120V AC) which has a battery backup (12V DC), or just a "pure" battery-powered model. Obviously, even if using shore power at RV parks, the detector will be on battery power 99% of the time. Any advice from those who use them?
RockyMTns is offline   Reply With Quote
Old 02-15-2012, 09:32 PM   #2
Mine takes two 9 volt batteries I see no need to take up a plug space.
Remember Carbon monoxide detectors need to be replaced every five years. Smoke detectors every ten years.
Old 02-15-2012, 09:53 PM   #3
I like Daniel's solution... YMMV
Old 02-16-2012, 06:55 PM   #4
Montana
Thanks for the advice.
Old 02-17-2012, 10:07 AM   #5
A Battery operated unit that has a readout. Check the wholesale clubs for the best prices.
Old 02-17-2012, 11:52 AM   #6
Trailer: scamp 13
battery operated, so when you get sick of it beeping and throw it out the window, the cord doesn't make it bungie right back at you.
just kidding.
but i would go battery, they last a long time, and why used even a little of your power plugs .
Old 02-17-2012, 01:50 PM   #7
Battery operated. The only false alarm we ever had was when, God rest her soul, Duchess had "gas" and was laying against it - seriously, the poor dog was horrified by it and found a more friendly spot after about the 3rd time. It took us awhile to figure this out but we were on target, as was she!
Cathy P. is offline   Reply With Quote
Old 02-17-2012, 02:05 PM   #8
I purchased the Kidde Digital Display model kn-copp-b at Sams Club for less than $20.
Old 02-17-2012, 02:48 PM   #9
Poor dog! agree with the battery operated being the better choose as most come with instructions as to how high or low they are to be mounted and there is rarely a plug anywhere near the ideal location for mounting. Also makes for one less thing pulling power from your battery if your Boon docking.
Old 02-20-2012, 01:10 PM   #10
Montana
Okay, so the consensus is battery-powered. Also sounds like I should consider mounting it to our dog's collar... or perhaps her tail!
Old 02-20-2012, 05:21 PM   #11
Rick G's Avatar
Trailer: 74 Boler 13 ft / 97 Ford Aerostar
Smile
I also have mine hooked up to the trailer battery, but I have an off/on toggle switch for the power to it. That way it does not use battery power in the day time when we are not using it, but does work at night when we have the furnace on and want it. It is only 0.2 amps, but every bit helps. I find it reassuring to hear the series of beeps as it charges up after it gets the power turned on.
Rick G.
Rick G is offline   Reply With Quote
Old 02-20-2012, 07:17 PM   #12
Pam Garlow's Avatar
Trailer: U-Haul 1985
Is a CO2 detector needed if someone only heats with electric cube heater? My trailer is most definitely NOT airtight, and I always sleep with the vent cracked too.
Old 02-20-2012, 07:25 PM   #13
Even cooking with propane the trailer should have a detector.
Old 02-20-2012, 10:01 PM   #14
Joe Z's Avatar
Trailer: 16 ft Casita Spirit Deluxe
Don't forget an LP sniffer down near the floor to detect for any gas leaks..... Mines hardwired into the 12 volt battery with an on/off switch
Old 02-21-2012, 10:10 AM   #15
Rick G's Avatar
Smile
No, CO (carbon monoxide) is only produced as a byproduct of combustion. In other words, if you don't have any combustion (propane furnace, stove), there should not be a problem. Your furnace is vented to the outside and should not create any interaction with your room air. However, the CO detector is there in case there is a leak and the combustion byproducts somehow leak into the trailer. Your stove uses room air and definitely creates CO. It is not safe to be used as a heater. An electric heater does not create CO.
A propane fridge could theoretically leak combustion byproducts into the trailer. That is why the burner is on the outside of the trailer and the access to the inside is sealed off. However, even if there was a leak, there is so much fresh air venting in the back of the fridge that I doubt it would be a problem.
CO2 is carbon dioxide, a natural byproduct of breathing and not normally something to worry about. It is a trace gas in the atmosphere and plants need it to survive. However, it is theoretically possible in an airtight room for several people breathing to use up all the oxygen over a period of time. That is why I always have a window vent cracked in the trailer overnight even if I am not using the furnace. The possibility of using up all the room air in one of these trailers is remote, since they are not air tight by any stretch of the imagination, but I do it anyway.
Hope that helps.
Rick G
Old 02-22-2012, 08:20 AM   #16
Trailer: Uhaul CT-13
Ohio
I bought a pure battery powered one for ours.
Panoz77 is offline   Reply With Quote
Old 02-23-2012, 07:30 AM   #17
Trailer: scamp 13
i don't worry about it. take a grand kid with you. they are in and out so often you have a total air change taking place several times per hour.
Carbon-monoxide detectors Darwin Maring Problem Solving | Owners Helping Owners 0 02-19-2011 11:51 AM
carbon monoxide alert trips circuit breaker..I think lloyd cicetti Problem Solving | Owners Helping Owners 7 10-02-2010 02:47 PM
3000 BTU Catalytic Heater / Carbon Monoxide Rob vanNostrand Modifications, Alterations and Updates 5 09-11-2009 12:24 PM
Carbon Monoxide Measurements Parker Buckley Problem Solving | Owners Helping Owners 23 03-04-2009 06:36 PM
carbon monoxide alarm Christi V. Problem Solving | Owners Helping Owners 3 04-18-2006 08:26 AM
