This CO Detector......I looked up on Ebay but only saw the plug in type....is yours battery operated, or is it a plug in model that you have chosen to just run off the battery "power outage option" ? I want to get a digital read out one myself.
thanks
Mine is the Atwood 900-0140, made by Kidde. I ordered it from PPL. Here's a link to it:
http://www.pplmotorhomes.com/parts/lp-gas/...co-detector.htm
I don't know if it will work, or if you'll have to paste the address into your browser.
It runs on three AAA batteries. The
propane detector is hard-wired in. Since the CO detector generally is mounted higher, I didn't want to have to run wires up to it. As it turns out, I'm glad it can be moved around.
Good luck!
Parker
