Case Awning on 13' Boler - Page 2 - Fiberglass RV
Old 08-25-2012, 03:05 PM   #15
Barbara the metal used for the brackets is 1-1/8" Wide x 1/8" thick.
The bracket is actually 2 pieces and they are attached together by one of the bolts that goes through the inside of the awning at the back.
The top pieces is 6 1/4" long in total and the section that is flat to the roof of the trailer with the bolt through into the inside of the trailer is 1 1/4" - the center of the bolt hole is a 1/2" from the end edge.
The lower piece is 4 1/4" long in total and the section that is flat to the trailer is also an 1 1/4" with the bolt (goes though into the trailer) centered 1/2" from the bottom edge. It is bolted onto the inside of the awning at the back with 2 bolts.
The whole awnings sits with the bottom back edge about 3/4" of an inch off the trailer.
Acorn nuts where used on the ceiling on the inside of the trailer where the bolt comes through - it also has a large washer on the inside under the rat fur.
As mentioned previously make sure you install it with butyl tape - mine wasnt and in heavy rains it dripped inside a little bit from 2 of the bolts - its been fine since it was redone with butyl.
A few more photos as the previous one was taken in the dark. Sorry about the glare but even though my old trailer is undercover it cant help but show off its shine! And guess what Its Not Floor Wax!
Old 08-26-2012, 01:34 PM   #16
Barbara Gardin's Avatar
Thanks Carol. That really is quite a shine.
Barbara Gardin is offline   Reply With Quote
awning, boler
Awning for Boler. Pat C Problem Solving | Owners Helping Owners 12 05-14-2013 09:58 AM
Fold-Up Carrying Case Solar Panels At Harbor Freight Joseph Domingos Modifications, Alterations and Updates 23 07-16-2011 05:51 AM
Case or roll up awning for 17' Bigfoot KeithA Problem Solving | Owners Helping Owners 19 07-09-2011 08:25 PM
13' boler awning carlb48 Classified Archives 8 07-25-2007 04:05 PM
Boler awning RobJ Classified Archives 1 03-18-2007 08:04 AM
