Casita Spirit battery operation question - Page 2 - Fiberglass RV
Old 07-07-2016, 12:48 AM   #15
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Originally Posted by CASITA BANANA View Post
I tried the compressed air thing and it didn't work. Taking the pedestal out is not a big job. You'll need a square drive for the screws; four or five around the top edge and maybe three or four on the inside bottom edge. That will give you access to the pump and the heater. If you've got the original heater, the anode rod is on the back side facing you. If the anode was never changed and the tank drained regularly, you probably have either a ton of gunk in there (best case scenario) or the tank is shot and the pieces are clogging up your water lines.
Not sure I want to believe anything about the hot water side as his is working fine, flows freely and is a separate line leaving the heater. The cold side is the problem.....somewhere past the pump which is common to both and working fine. The faucets are not it as they flow fine with the hot side running. A city water connection has the same problem, eliminate that too. The only thing left is the cold line. Very well could be something in the line and compressed air from the faucet towards a disconnected outlet on the pump may flush it out. Unless there has been a stray valve installed by a PO..........interesting problem<_<.
Old 07-07-2016, 08:19 AM   #16
I'm a noob, be here is an idea.
I ran into this at our campground on a conventional trailer. I winterizing valve was left open, and it took us hours to figure out the cold wate was running out on the ground.
bookernoe is offline   Reply With Quote
Old 07-07-2016, 11:23 AM   #17
Trailer: 1992 Casita Spirit
water flow
Think I solved my problem....took off cold feed line under kitchen cabby and turned on house supply water. Water flowed thru supply line....great!!! When I screwed supply line back on faucet n turned on cold water....no flow!! That tells me my prob all along has been the faucet! Never gave that a thought cause the hot side had great pressure. Guessing the hot n cold have separate valves in the faucet. Ordered faucet today from Little House just up the road from me.
xbassman is offline   Reply With Quote
Old 07-07-2016, 03:27 PM   #18
Interesting, when I said the faucet was fine because of the hot flow I never considered the mixing valve. How about taking it apart to see if you can find the problem?
Old 10-24-2017, 03:07 PM   #19
Just got a 2nd hand 92 Casita Spirit Deluxe in amazing condition. Checked the 12v battery, large marine type Stowaway I think. Anyway, after putting my battery charger on it for a day it read 12.5v. When I hooked up the Black/Green/White wires, black being +, and NOT plugged into any external elect., I figured the 12v lights in the trailer would light up....well not a light to be seen. Any ideas on why not? Where would I go next to find out why lights are not burning?
Another question.....when I connect my water hose from my house to trailer, lots of pressure at my place. The hot water side of the sink and shower give me a great amount of water/pressure. BUT when I turn on COLD side I just get a trickle????? Why???
Hi. We just bought a 1992 Camera as well. We have just finished up redecorating and ready to go in on first trip. We have the same battery problem. How did you resolve your problem?
Gerles71 is offline   Reply With Quote
battery, casita
Suburban Furnace in operation kevin61 Problem Solving | Owners Helping Owners 0 05-20-2009 11:47 AM
VIDEO Operation of Boler Suburban Furnace kevin61 Problem Solving | Owners Helping Owners 0 10-26-2008 04:16 PM
Awning Operation Lainey Problem Solving | Owners Helping Owners 2 07-05-2008 05:37 PM
DC operation Legacy Posts Problem Solving | Owners Helping Owners 12 05-10-2003 09:50 PM
