Casita water tank anode - Fiberglass RV
Old 12-06-2010, 03:18 PM   #1
Trailer: 2007 Casita Spirit Delux 16'
I had to stand on the breaker bar to get it loose. Put Teflon tape on the new one. Any ideas on what it should be torqued to?
Ed in Pensacola is offline   Reply With Quote
Old 12-06-2010, 04:20 PM   #2
WtMtJim's Avatar
Trailer: 2010 16 ft Casita Freedom Deluxe
I read somewhere 8 or 9 pounds, but what I do is screw the anode in finger tight, fill the tank up with water and then use my torque wrench and just tighten the anode gradually, til it quits leaking. I quit using teflon tape or plumber's goop. Doesn't seem to need it. I take my anode out after every trip and I use a small wire brush - looks like a wire tooth brush - to clean the threads on the anode and the tank opening after every trip, too. Haven't had any problems or leaks yet.
WtMtJim is offline   Reply With Quote
Old 12-06-2010, 04:37 PM   #3
Matt in SV's Avatar
The manual wasn't much help, was it? I looked, too!
Be sure not to use that breaker bar to put it back in! Make sure it's threaded properly finger tight on the socket before you use a tool. The balance is odd because the weight is all on the rod end, so you want to be sure you have it straight to avoid damaging threads.
I used a short wrench, choked up quite a bit and tightened enough just to get it snug.
Check for leaks!
Planning our next Escape!
Old 12-06-2010, 05:41 PM   #4
The Teflon tape may make it easier to get it back off in the future. I use the tape and tighten like the 2 guys above. Never to tight, just enough so it will not leak.
casita
Auxiliary Fresh Water Tank, Transferring Water Adrian W General Chat 0 09-05-2010 02:36 PM
Suburban hot water heater anode difficult to install Steve M. Problem Solving | Owners Helping Owners 7 05-25-2009 07:22 PM
Gray water tank for '91 Casita Geoffrey Cobb Problem Solving | Owners Helping Owners 1 10-11-2007 11:38 AM
