casita window top/bottom center strip - Fiberglass RV
Old 03-03-2016, 02:04 PM   #1
Trailer: inTech
Kansas
don't know the proper terminology for this. it is the seal in the middle of the window that goes from the top of the window to the bottom that allows the glass to slide by it while keeping water out. mine have all shrunk with time so that the windows have a big space at the top that allows water to come in. can i find this material and replace it, or do i have to buy all new windows? help!!
lrb945 is offline   Reply With Quote
Old 03-03-2016, 02:09 PM   #2
tractors1's Avatar
Trailer: Escape 21 - Felicity
You could probably buy it through Casita or Hehr, but then you'd have to install it. Any RV (and many window shops) can fix it - Casita uses Hehr windows, the biggest name in RV windows, so ordering the seal shouldn't be an issue. RV place would probably have some in stock.
Charlie Y
Old 03-03-2016, 02:11 PM   #3
Trailer: inTech
Kansas
i'll check into it further with hehr--thanks!
Old 03-03-2016, 02:23 PM   #4
tractors1's Avatar
Repair seals:
Page Title
Charlie Y
Old 03-03-2016, 03:05 PM   #5
Trailer: inTech
Kansas
i think it is called a 'sweep seal'. not sure how much luck i will have in replacing it myself, but i have it ordered! if anyone has done this, advice would be most appreciated. thank you!!
casita
Rubber strip missing on bottom of Trillium back window parmtree Problem Solving | Owners Helping Owners 2 10-23-2014 02:55 PM
Boler window bottom trim glamourpets Care and Feeding of Molded Fiberglass Trailers 14 09-05-2014 10:43 AM
Cheapest Place to Buy Front Window seal with locking strip idiotsniff Problem Solving | Owners Helping Owners 58 07-10-2012 02:36 PM
Scamp 1988 needs Weather strip for Jensen top hatch Ben Chappell Problem Solving | Owners Helping Owners 2 05-14-2008 08:38 PM
Trillium Exterior Window Strip Krysti Peck Problem Solving | Owners Helping Owners 4 05-13-2007 06:32 PM
» Trailer Showcase
Bebe
MMiller
ECO
Suanne
