Caulk silicone on top of butyl tape ? Yes or no - Fiberglass RV
Old 10-10-2017, 08:20 PM   #1
JRC
Trailer: market
First time question. OK I purchased a trillium that needs work. I have read many things on this site. Very helpful.
I have removed cleaned, applied butyl tape and reinstalled 2 windows so far.
My question is this. Once I trim the tape do I put a bead of silicone on top of the butyl tape or just leave it as is.
I read so may things to stay away from silicone.
Thanks for any advise
JRC is offline   Reply With Quote
Old 10-10-2017, 08:38 PM   #2
rbryan's Avatar
Arkansas
You read right. Once you apply silicone, it's extremely difficult to remove it. Nothing sticks to silicone - even more silicone. Just go with the Butyl tape. It's designed for things like sealing windows, and is easily replaced if it deteriorates. If you want to help the window seal last a bit longer, add a bead of clear ProFlex or Lexel (they're not silicone) along the top ledge only, not all the way around.
Old 10-10-2017, 08:39 PM   #3
Virginia
If you do it right you will not need to silicone.
Neto is offline   Reply With Quote
Old 10-10-2017, 09:44 PM   #4
Even if you do it wrong, you don't want silicone!
Old 10-11-2017, 06:18 AM   #5
JRC
Trailer: market
Window sealing
OK . Thank you for the replies. I guess I will just trim the butyl edge of the tape at a 45 degree angle.
Old 10-11-2017, 07:52 AM   #6
silicone
I like silicone use it all the time!
bob
Old 10-11-2017, 08:49 AM   #7
Trailer: 2008 Casita 17 SD
bob
Once it ages a bit and loses its adhesion, I'm thinking you won't like it so much down the road.
Old 10-11-2017, 10:11 AM   #8
IllAnnoy
I still like it after decades, how much longer 'til I don't?
Old 10-11-2017, 10:21 AM   #9
Kai in Seattle's Avatar
NO, NO, a thousand times, NO silicone!
And we used a popsicle stick end to "round" the butyl tape to a nice edge.
Nothing sharp.
BEST
Kai
Semper ubi sub ubi.
Old 10-11-2017, 10:24 AM   #10
new silicone
while at walmarts I bought a new silicone caulk marketed by the people that make the wood glue best I have found!
bob
Old 10-11-2017, 12:50 PM   #11
Trailer: 1973 Trillium
Window sealing follow-up question
Hi, I have always used the RV proflex. I am sealing up my windows and would like to know why, after trimming the butyl, the recommendation is only to run a bead along the top of the window. Would it not be good to seal around the whole frame?
Thanks!
Trailereva is offline   Reply With Quote
Old 10-11-2017, 03:32 PM   #12
rbryan's Avatar
Arkansas
bob
Silicone's a bad idea on a fiberglass trailer. There are a number of reasons. It's been discussed ad nauseum on this forum as well as many others. Read through all the links referenced in this thread.
Why is silicone bad?
If you're still loving silicone after all that, there are plenty of blogs with advice not to use it, like this one:
http://www.roadworkplay.com/2013/11/...ng-our-camper/
Or this one:
http://www.liveworkdream.com/2016/08...or-rv-sealant/
Once you realize it's extremely difficult to remove, and nothing sticks to it, silicone loses it's appeal pretty quick. But hey, knock yourself out.
Old 10-11-2017, 10:56 PM   #13
If done right with the butyl tape the joint will be sealed. The only reason for any type of overcoat in the product you choose is because exposed butyl grabs dirt and wont look good over time. You cant wash the dirt out of exposed butyl tape.
Butyl Tape, Silicone and sealing Beth Teichmann Problem Solving | Owners Helping Owners 108 08-14-2019 09:57 AM
Butyl tape - putty tape? Janb313 Problem Solving | Owners Helping Owners 10 03-23-2013 10:21 PM
Where to buy Butyl Caulk? D Davis Problem Solving | Owners Helping Owners 18 03-20-2013 02:43 PM
Best Butyl caulk? Craig D. Thompson Care and Feeding of Molded Fiberglass Trailers 7 02-25-2012 08:02 AM
Butyl tape vs. butyl caulk- newbie looking for input Jason, M Problem Solving | Owners Helping Owners 9 08-11-2008 02:57 PM
