Changing a tire - Fiberglass RV
Old 10-19-2013, 06:50 PM   #1
Down the Road's Avatar
Trailer: Hunter Compact Jr
Louisiana
Changing a tire
My 1971 Hunter Compact needs new tires. I have a 3500 load axle. I'm thinking the jack should only go under the axle near the wheel. Am I correct?
Down the Road is offline   Reply With Quote
Old 10-21-2013, 07:39 AM   #2
Steve & Terri's Avatar
Name: Steve & Terri
Trailer: 2004 Scamp 19 ft 5th Wheel
That's where I put my jack when I changed the tires. I also used a couple of jack stands next to the hydraulic jack, just for safety in case the trailer shifted while I was changing the tires.
Steve & Terri is offline   Reply With Quote
Old 10-21-2013, 08:15 AM   #3
honda03842's Avatar
Name: Norm and Ginny
Steve is right. It's easy for the trailer to shift since it's balance on the jack and one wheel.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
honda03842 is online now   Reply With Quote
Old 10-21-2013, 08:40 AM   #4
I suggest always hooking up to the TV before jacking up to change a tire. Then you can lift on the axle without it moving around. Much more stable and a lot safer, especially with the tongue light Hunter Compact.
BTW: I take it you don't have the original axle any longer
Old 10-22-2013, 07:39 PM   #5
Louisiana
Thanks for replies. The axle is not original, it was replaceda few years ago.
Old 10-22-2013, 08:36 PM   #6
This is a leaf spring axle correct? You should NEVER lift the trailer under the axle, if it's a torsion axle. Lift on the frame close to the tire.
Old 10-23-2013, 04:40 AM   #7
Louisiana
No torsion axle here. Good point. Thanks.
Changing from a fifth wheel greenmtnman Towing, Hitching, Axles and Running Gear 21 08-30-2013 12:04 PM
Changing the locks kerk72 Problem Solving | Owners Helping Owners 4 08-12-2012 08:27 PM
Changing user name bkboler General Chat 8 04-14-2012 12:18 PM
Changing Username Booker B. Forum Admin, News & Announcements 4 03-14-2008 08:56 PM
changing tires cyndi H Towing, Hitching, Axles and Running Gear 8 09-17-2007 12:27 AM
