Charger heat ?? - Fiberglass RV
Old 03-29-2012, 10:55 PM   #1
Trailer: Had a Scamp sold , Now have a Casita
New Mexico
Question Charger heat ??
Hi group
We just picked up a used 2012 13' Scamp. In the drivers side, lower, rear compartment ( under the seat ) there is the electric fuse box and a separate battery charger. The charger produced heat, the compartment is closed off.
Is this a problem ? Should I vent that area ?
Thanks
Tom
Tom Hansen NM USA is offline   Reply With Quote
Old 03-30-2012, 09:46 AM   #2
Hey Tom
I guess it depends how much heat is generated, might put a themometer in there and close it up for a period of time, this will let you know if too hot. I be sure the charger is not sitting on the floor but on a raised bracket with space on all sides.
Ron
RRJR is offline   Reply With Quote
Old 03-30-2012, 10:02 AM   #3
Tom the battery charger you are seeing I suspect is your converter - thats where mine has been located since 92 without a problem. If it needed venting I suspect Scamp would have done that long ago - just try to avoid putting anything on it - I put a small grate/fence inside the hatch to stop things stored in the hatch from coming in contact with it.
Old 03-30-2012, 10:07 AM   #4
Raz
Raz's Avatar
Hi Tom and welcome to the forum. While heat does kill electronics it might take 50 years to do it. You are probably fine but what I would recommend would be to find a copy of the manufacturers installation instructions and see if the Scamp installation meets their guidelines for ventilation and clearance. By the way, congratulations on the new Scamp. Raz
Old 03-30-2012, 10:47 AM   #5
Trailer: Class A Motorhome
Heat Buildup
I haven't heard all that many good things about the "Americana" (sp?)converter, and personally had one go up in smoke in our 2007 Scamp. If you check at your local RV store they have 3" diameter "Battery Compartment Vents". I would put one on the outside or two (one high & one low) on the front of the dinette seat on the inside. Cheap insurance that might help. Even more so if you happen to also have a water heater living in that same space.
Heat and Air Butch H Problem Solving | Owners Helping Owners 5 09-12-2010 08:25 AM
Window a/c with heat? Scott B. Problem Solving | Owners Helping Owners 6 09-10-2010 02:22 AM
Escaping the Heat Jackie Camping, Campout Reports 10 08-17-2006 02:11 PM
Radiant heat... Al Stansell Modifications, Alterations and Updates 4 02-24-2006 01:31 PM
Colors & Heat Legacy Posts Electrical | Charging, Systems, Solar and Generators 25 07-11-2003 12:09 PM
