These are some pics of the seals
The first pic shows the top seal which is the original that I just replaced, 1 1/8". The bottom seal which is identical to Scamps, only 1".
The second pic is the size comparison between the old and Scamps.
The third pic is the seal I found today (left) with the original (right).
The fourth pic is Scamps on left and what I picked up today on right.
When I say Scamps, I just mean the seal that is the same size as the seal from the beginning of this thread.
It may be hard to tell but the channels for glass and body from
scamp aren't as deep as the the original but the channels are the same width on all of them.
The
fiberglass channel on the original and todays find are 1/2" and window channel is 3/8". On the smaller seal the
fiberglass channel is 3/8" and window is only 2/8 ".
I guess what I should have done from the beginning is trace out the actual cut out for the window, measured the distance between the channels and had the window cut accordingly. The distance between the channels is only off by 1/16" but as I said earlier, there seems to be some play in the seal I put on over the weekend. I can slide it back and forth between the body and the window.
