knowing a little how Jon uses his trailer sorta confirms my assumptions....I use quite a bit less power although I have not dug into it enough to put a number on my typical daily useage (as he has)
one thing that sticks with me is how complicated the 12V "thing" is...one could spend a lifetime or research and learning and still the findings would include words like "often" "sometimes" "almost".....compare that to other sources of heat or power and the numbers/findings are always exact to a decimal point!......maybe that's why 12V and
solar are so much fun to "play with" in the end
Jon when you mounted your batteries on the back bumper (great spot BTW) did you have to move some other things around to adjust tounge
weight??? or did none of that come up.....really enjoy your blog BTW
