Chevy Colorado 7-Pin Connector - Fiberglass RV
Old 11-20-2019, 03:39 PM   #1
Trailer: Hunter Compact Jr 1972
Does anyone know if my 2017 Chevy Colorado ZR2, which has the factory installed brake controller and 7-pin connector, has the same wiring as the new Casita I pick up mid-December? If not, what do I do?
janel is offline   Reply With Quote
Old 11-20-2019, 04:59 PM   #2
AC0GV's Avatar
Wisconsin
7 pin connector
It 'should', it's an industry standard. Although some times the fuse is not installed in some trucks.
Old 11-21-2019, 12:51 PM   #3
jgilliam1955's Avatar
Trailer: Casita Liberty
Virginia
I have a 2015 Colorado. Check your book. I had the 7 pin connector but not the the brake control. You will need a sway bar too. I had the Brake controller installed myself.
Been with my sweetheart since 1969
2015 Chevy Colorado & 2019 Casita owner
If I won the award for laziness, I would send somebody to pick it up for me.
jgilliam1955 is offline   Reply With Quote
Old 11-21-2019, 08:51 PM   #4
LarryB.'s Avatar
Trailer: Casita17'Spirit Deluxe (aka: Tweaker's Casita)
Southwest Ohio
Yes, “it should”.
I have a 2018 Chevy Colorado WT which came without a tow bar, a braking controller and a trailer connector. I found that the Chevy wiring harnesses for the breaking controller and the Chevy wiring harness for the trailer connector matched the “standard” color codes when adding those items. Also, the color codes for the trailer connector's wiring harness matched the wiring harness as documented in the Casita Travel Trailer A-Z Owners Guide.
All together, the (now upgraded) truck and my (new to me) 2007 Casita Spirit Deluxe connect up just fine.
LarryB. is offline   Reply With Quote
Old 11-23-2019, 03:12 PM   #5
ststefan's Avatar
Trailer: 1979 Boler1700
Maple Ridge, B.C.
My 2016 Colorado came with the tow package less the controller. The wiring matched our '79 Boler. I bought a brake controller and installed it myself (mostly plug and play).
I also got a 7 pin tester from Princess Auto. Great item to carry in the tool box.
https://www.princessauto.com/en/deta...er/A-p8271173e
Old 11-30-2019, 11:45 AM   #6
My 2017 Canyon has the factory set up and yes it is standard and the sister truck the Colorado should be the same set up.
lgboro is offline   Reply With Quote
Blue wire on 7 pin connector shows 12v all the time ? Mikeny Towing, Hitching, Axles and Running Gear 5 04-20-2008 02:11 PM
Yellow wire on 7 pin connector ? Mikeny Towing, Hitching, Axles and Running Gear 2 04-13-2008 01:22 PM
boler 7 pin connector troubles al gilliland Problem Solving | Owners Helping Owners 6 04-24-2007 01:02 PM
7 pin connector Dan Simon Problem Solving | Owners Helping Owners 2 08-05-2006 09:54 PM
Wiring 04 Highlander to 7 pin Bargman connector Gary Little Towing, Hitching, Axles and Running Gear 18 06-02-2006 07:46 PM
