Cig Lighter in 16' Scamp - Fiberglass RV
Old 09-14-2019, 08:58 PM   #1
Idaho
First off, I apologize if this topic has already been addressed, but I didn't see any way to search the threads...
I am hoping someone may have an idea why the cigarette lighter in my 16' Scamp does not have any juice? All of the other lights and appliances work OK. I have tested the plugs/wires I am using and they are working as well.
This isn't a life changing issue, but would like to resolve if possible.
Thanks Everyone!
maxman is offline   Reply With Quote
Old 09-14-2019, 09:54 PM   #2
One thing at a time. How to search threads. Use the Site search / Google box at the bottom.
Old 09-14-2019, 11:33 PM   #3
AC0GV's Avatar
Wisconsin
Check the crimps
If all of the fuses are good check the factory crimp connectors. Many have had them pull apart. be sure to check both the + and - wires. Unlike a car you need both in a fiber glass RV
Old 09-15-2019, 04:04 PM   #4
Thanks Everyone!
It should have its own fuse. It could be an inline fuse so follow the wires to where they hook in to the power and ground. Have you actually checked to see if there is power to it? Check it very carefully inside the receptacle. If there is power you may have the problem we encountered once. The item I was plugging into the receptacle had a shorter than normal plug and it didn't touch far enough into the receptacle for a connection. So I found one with a little shorter receptacle. I also got one once that the inside of the receptacle wasn't solid so when I plugged in, the part that wasn't solid pushed sideways far enough to touch the outer part and blew fuses. It had worked for a year or more. Guess it got weak inside. Hope this may help.
light, scamp
Stove Top Peizo Lighter Tamid Problem Solving | Owners Helping Owners 3 07-20-2010 03:34 PM
Lighter Trillium? Linda D Care and Feeding of Molded Fiberglass Trailers 21 02-17-2010 10:08 AM
12v lighter install Flygal Problem Solving | Owners Helping Owners 14 05-07-2008 07:02 PM
Lighter than air TT Alistair Camelford General Chat 10 12-05-2006 04:59 AM
Lighter problem Legacy Posts Jokes, Stories & Tall Tales 4 12-13-2002 05:24 PM
