City water woes - Fiberglass RV
Old 08-15-2019, 09:10 AM   #1
Trailer: Escape 21 'on order'
Talking City water woes
Fought the city water line leak gremilns for 2 years and finally had to throw in the towel(s) as it were.. Seems no matter what I tried, the connections in the water line , the pressure reducer thingie, and the Camco filter wd leak...at their own pace..leaving wet dirt or pavement under the front of the trailer. I tried to carry a selection of washers, teflon tape etc but sometimes the darn stuff just leaks. Is this a common problem or are we just haunted" ;-)
Fred762 is offline   Reply With Quote
Old 08-15-2019, 09:26 AM   #2
ZachO's Avatar
Trailer: 91 Bigfoot 17
Montana
I'm sure others have found solutions, but having been around here a couple years now I know it's a common problem.
If I were parked somewhere with water connections, I think I'd just fill my trailer tank as usual and use my water pump.
Old 08-15-2019, 10:40 AM   #3
My trailer will leak on city connections sometimes, but it is leaking back to the water tank through the check valve and the water pump.
The vent dribbles a little water out after it has overfilled the water tank.
Could this be your problem?
Old 08-15-2019, 11:25 AM   #4
Thats what I do.. it also has the advantage of helping you gauge how much water you have used and how full the waste tanks are.
City water connections are more trouble than they are worth unless maybe you have sewer also at the site and like long showers in the camper.
Old 08-15-2019, 12:40 PM   #5
I use a 90 degree fitting on the trailer hose connector, I think it helps take some strain off the fitting rather than just attaching the hose direct. The plastic hand wheel from Little House makes it easy to tighten the trailer connector. Pressure regulator goes on the campground spigot, then water filter, then hose, so everything is under the regulated pressure.
Old 08-15-2019, 02:36 PM   #6
It is not brain surgery, it is just little bits of stuff and one piece connects to the next. So start and point A and keep replacing pieces until you get to the other end of the line. All new fittings and hoses
Old 08-16-2019, 09:26 PM   #7
Thumbs up pressure reg
Ya'll may have hit my problem..looking at the line I see the pressure reg is near the trailer end of the line..I will try it at the spigot, then the camco, then the hose.. may work thanks !!
Trillium City Water Inlet Woes David Swinnard Plumbing | Systems and Fixtures 32 02-19-2018 05:11 AM
Fresh Water Tank Woes slowpat Problem Solving | Owners Helping Owners 5 07-28-2016 11:10 PM
water heater woes Dan B Problem Solving | Owners Helping Owners 16 08-01-2011 06:40 PM
Water Heater Woes Roger H Problem Solving | Owners Helping Owners 1 10-14-2008 03:22 PM
My turn to cry... water woes Deb in MN Problem Solving | Owners Helping Owners 3 04-26-2006 04:38 PM
