cleaning rat fur - Fiberglass RV
Old 09-04-2013, 07:24 AM   #1
Trailer: 13' scamp
cleaning rat fur
I just bought a 16 ft scamp. We're giving it a cleaning. Cushing covers went through wash machine on gentle cycle - worked well. Used power washer and a small amount of simple green on the foam cushions - that worked well but took 2 days of warm sunshine to dry. We are now looking at ways to clean/shampoo? what I believe you call rat for covering the walls and ceiling. It doesn't appear to be very dirty but trailer was built in 1997 and has kind of a stale smell. Help?
john in flushing is offline   Reply With Quote
Old 09-04-2013, 09:03 AM   #2
I use ulpolstery cleaner from the auto parts store. I wear rubber gloves and spray the fabric very wet and work it by hand and then use my wet/dry shop vac to vacuum it dry removing the dirty cleaner as we go. I work about a 2 foot square area then suck it dry and move to the next area. I use my gloved hand because its easy to tease the fabric on my version of rat fur. Make sure to open all your windows as some of this spray stuff is very fume'ie. If I didnt use the ulpolstery cleaner I would probably use woolite cleaner.
Old 09-04-2013, 09:55 AM   #3
Have found due to the properties of the rat fur it does not absorb or hold a lot of dirt. If you can find a portable steamer that works really well. I have actually used a foam carpet cleaner on my lower door area that worked pretty well also but found that you cant rub to much on the rat fur as it tends to pull and get a little shaggy ;-) thus the reason using a steamer seems to work better as there is little rubbing on the rat fur.
Old 09-04-2013, 11:52 AM   #4
Trailer: 2014 Escape 21
Virginia
I agree with both Steve and Carol. A steamer followed up with a shop vac. for general freshening up and cleaning. For stains and door bottom I use Blue Magic, carpet stain and spot remover. You may need to brush lightly in one direction. If it gets shaggy like Carol described I just trim it up with a pair of scissors. For odor removal and cleaning we also use white vinegar because of perfume and cleaner allergies.
Eddie
Eddie Longest is online now   Reply With Quote
Old 09-04-2013, 07:08 PM   #5
I just vacuum and use upholstery spot remover on the bottom of my Scamp's door. The trailer body rat fur was actually more dusty than dirty. I found vacuuming really cleaned it up well.
Whatever you do DON'T saturate the rat fur with water or anything else. You don't want the glue to release
Cleaning the "rat fur".... Cricket Care and Feeding of Molded Fiberglass Trailers 5 10-01-2012 06:07 PM
Rat Fur Sagging Baj Problem Solving | Owners Helping Owners 5 05-07-2011 07:06 PM
What is rat fur Gene B General Chat 5 06-04-2009 05:08 PM
cleaning the rat fur Diane G Care and Feeding of Molded Fiberglass Trailers 16 08-27-2008 11:04 PM
Rat Fur DanPatWork Problem Solving | Owners Helping Owners 2 08-24-2007 12:52 PM
