Cleaning the drains on Hehr Sliding Windows - Fiberglass RV
Old 01-04-2003, 06:11 PM   #1
Charles, I had a window leak last nite, so today I was out there with my chunk of weedwhacker mono but it just wouldn't feed in. Whilst messing about with it, I discovered the little plastic hood on the frame can be removed and replaced (it can also be lost if you drop it in the wrong place, but that's another story), it has a bending clip on each side.
With the hoods removed, I was able to put a thin metal rod (small bronze braising rod) all the way across, from one opening to the other, without bending it. In the process, I removed a plug of mud and calcium chloride (courtesy of Canadian roads,esp Yukon Terr) about 3/4 long that wouldn't budge for the mono.
Sure wish I had the crankout windows on the rear; I have had zero problems with the ones on the side and they give more ventilation and protection from rain.
Pete, wondering where to get another of those little hoods, and Rats
Old 01-06-2003, 01:00 AM   #2
Murphys Law
Pete, wouldn't ya know it, fix one problem and create a new one.:crazy-ii
Wonder if Hehr would sell you just the little hood thingie?
Karen
Old 01-06-2003, 10:20 AM   #3
Good tip Pete!
Good tip Pete!
Where is the plug, on the face of the window frame? I always thought that was to cover up a rivet used to hold the window in place during installation.
Learn something new every day!
Was the "Yukon" plug along the top, bottom or side of the window?
>>small bronze brazing rod
What's that? I wanna add one to my "stuff" I carry, just in case!
Old 01-06-2003, 12:40 PM   #4
The plug was cemented mud inside the drain channel (left side in short, curved channel), having blown in there during my various wanderings and then being wetted down by rain. The hoods are on frame bottom (squeeze sides together to remove) and cover slot hole that goes in two directions each. Rod to break it up if needed, then fuzzed-up whacker mono to drag and push the dirt out.
Brazing rod comes in various sizes, most of mine are about 1/32" I think, left over from oxy/acetylene torch I had in a previous life, rods being retained as being potentially useful. Were I looking for more, or something similiar, I would go to someplace like Ace Hdwre and look in the carton of various hobby supplies of brass and aluminum rods, angles, flats, balsa, etc., where you can buy just one or two, not a whole welding supply shop tube of them.
Pete and Rats
Old 01-06-2003, 01:32 PM   #5
Rods
I carry insulated solid copper electrical wire in two sizes, AWG 14 and AWG 12. It's the handiest thing since water muffins.
If you strip the wire bare, it's a good soft rod for cleaning. If you leave the insulation on you can twist-tie with it or you can form it (it's very malleable) into hooks or other useful shapes.
It's cheap, cheap, cheap.
Old 01-06-2003, 05:04 PM   #6
Does anyone have a picture of the hood/cover? I can't picture where it would be.
windows
Cleaning aluminum windows Amy M Problem Solving | Owners Helping Owners 13 04-09-2019 12:49 AM
Installing small Hehr windows Amy M Problem Solving | Owners Helping Owners 2 01-27-2010 01:43 PM
Cleaning the windows in a 75 Trillium 1300 Darren Pettis Problem Solving | Owners Helping Owners 1 10-30-2009 10:14 AM
Hehr window mouldings Al Nelson Problem Solving | Owners Helping Owners 3 08-15-2007 11:23 PM
Hehr Window Software David Schroeder Problem Solving | Owners Helping Owners 7 01-31-2007 01:16 PM
