cleaning the windows - Fiberglass RV
Old 07-06-2014, 08:39 PM   #1
Saskatchewan
When we bought our Trillium it was squeaky clean. While camping earlier this week I noticed that the windows are definitely needing a clean up job. Today was going to be the day but it rained so I put that job on the "Later" list. Now I'm wondering HOW one cleans those wind out window panes (jalousies?). The outside should be a breeze - but how DO you reach in to wash the inside? Do you take out the screen? Use a rag on a stick? Looking for suggestions before I tackle the job.
Hazel in Sk is offline   Reply With Quote
Old 07-08-2014, 05:37 AM   #2
CampyTime's Avatar
Trailer: Scamp 13' Standard
I've thought of the same question myself on my scamp awning type windows. For the screens, just thought I'd run a vacuum nozzle attachment to suck the dirt off of them. Yes a cloth on the end i
Of a stick or long butane lighter would work if you could get your fingers on the end and hold the cloth on somewhat or just let the pressure hold the cloth to the glass as you slide across with windex.
I'm camping now and after 2 thunderstorms on the lake my windows are filthy too! Always something to do!
CampyTime
Old 07-08-2014, 07:36 AM   #3
Open the jalousie windows wide open and you can clean the backside from the outside of the trailer.
Eddie
Old 07-08-2014, 10:23 AM   #4
Timber Wolf's Avatar
North Florida
[QUOTE=Hazel in Sk;468741]I'm wondering HOW one cleans those wind out window panes (jalousies?). Use a rag on a stick? [QUOTE]
Ah ha! The old rag on a stick routine.
Old 07-08-2014, 01:24 PM   #5
Roger C H's Avatar
Smile Windows? We don't need no stinkin' windows!
I just remove the screen from the inside. Of course, I have aluminum windows in my brick and mortar home so I am familiar with the process.
Just place your fingers against the frame next to the screen and you will find the screen will move in one direction, usually up. Then, holding the frame up, pull the bottom or opposite side out and the whole thing should come out easily.
How to Remove Window Screens | eHow
Old 07-08-2014, 02:32 PM   #6
Wind fully open and clean from the outside. Much easier than taking out the screens.
RRJR is offline   Reply With Quote
Old 07-08-2014, 05:27 PM   #7
Ian G.'s Avatar
as Roger said the screens just pop out. Lift the screen up from the inside by lifting on the screen frame, then gently pull the exposed bottom of the screen towards you. You may have to remove the window crank to fully remove the screen.
Old 07-08-2014, 08:46 PM   #8
Saskatchewan
I wonder how I knew that the owners of eggs would have suggestions for me for cleaning the windows. Now all I have to do is get outside and get busy! Thanks guys!!
Old 07-08-2014, 09:45 PM   #9
WildBirder's Avatar
HI Hazel,
I'm curious to know if your windows don't open far. There have been a few suggestions to just open them further. The panes on mine go nearly horizontal when cranked all the way.
Cheers,
Mark
1969 Boler
(#183)
WildBirder is offline   Reply With Quote
Old 07-11-2014, 10:10 PM   #10
Saskatchewan
Our little Home Away From Home now has clean windows. They cranked out enough for me to get my hand between the panes!
windows
Cleaning aluminum windows Amy M Problem Solving | Owners Helping Owners 13 04-09-2019 12:49 AM
Windows, windows, windows Matt4483 Problem Solving | Owners Helping Owners 24 02-10-2016 01:50 PM
Replacing the rectangle aluminum windows with modern rounded corner windows Evergreen Modifications, Alterations and Updates 16 10-29-2010 12:09 PM
Cleaning the windows in a 75 Trillium 1300 Darren Pettis Problem Solving | Owners Helping Owners 1 10-30-2009 10:14 AM
Cleaning the drains on Hehr Sliding Windows Legacy Posts Problem Solving | Owners Helping Owners 5 01-06-2003 05:04 PM
