closet rod for 1985 scamp - Fiberglass RV
Old 03-05-2012, 11:31 AM   #1
sugermc's Avatar
Trailer: 1983 13 ft Scamp and 1985 13 ft Scamp
Hi, I was putting together the 2nd scamp and found I do not have the closet rod for the closet
Was wondering, if anybody has one or where I can buy one, Scamp parts has not given an answer yet
The rod in the first scamp is kinda nifty, it's about 3/4" and has an angle to one end, thats the side that goes to the outside edge and a screw goes thru the shell and is threaded into it. the other end just has a plate on the end of the pipe, that a screw goes thru the fiberglass closet frame and threaded into that side.
Never had the other closet taked apart so I do not know if there is a threaded part in the pipe/rod, to enable the screw to be threaded into it, or if the pipe/rod is solid with the threads tapped into it.
Was hoping to find one than trying to make one, any help would be greatly appreciated Thanks SugerMc
sugermc is offline   Reply With Quote
Old 03-05-2012, 01:16 PM   #2
SugarMc you might want to call the Scamp parts department - in my experience they are not great at responding to emails.....
Old 03-05-2012, 02:55 PM   #3
IllAnnoy
It's a welded piece made from 1/2" or 3/4" thinwall conduit with a piece of thin plate at the ends. It would be easy to make a new one if you have a MIG and a few minutes.
You could instead simply cut a couple pieces of 3/4" plywood with a hole drilled in the middle, slide them onto a piece of conduit and attach the wood at each end.
Keeping the hangers on the rod in the hanging closet Kent I Problem Solving | Owners Helping Owners 5 05-26-2008 08:09 PM
Scamp Closet Question Don Fowler Problem Solving | Owners Helping Owners 4 02-16-2007 07:52 PM
My 13' Scamp A/C in closet install Bob H Modifications, Alterations and Updates 9 03-29-2006 06:18 PM
Scamp 13' Closet Jackie Modifications, Alterations and Updates 5 12-01-2005 06:32 PM
Removing the closet in a 13 ft scamp Legacy Posts Problem Solving | Owners Helping Owners 2 07-02-2003 07:48 PM
